Horrible Vibrations
Old May 16, 2012 | 02:06 PM
Philipsterle's Avatar
Philipsterle
Horrible Vibrations
Hey everyone, Since I have known my fiancee, her 2001 ford expedition has made the most horrific vibrating sounds. Some things you should know...
1. Does not make the sound in park.
2. Only occurs when the engine is hot.
3. Cannot hear it at high speed (15+)
4. When stopped with the car in gear the noise is deafening, when she takes her foot of the brake the noise dissipates.
I first thought it was the heat shield on the catalytic converter, so I removed it and the sound persisted. I think it may be the front cover on the transmission, But Im not very car savvy so I do not even know what that thing is called to search for a solution.
If anyone knows anything, please let me know.
Old May 16, 2012 | 04:45 PM
Papa Tiger's Avatar
Papa Tiger
Is the trany mount broken?
Old May 16, 2012 | 04:49 PM
Philipsterle
I do not think that the mount is broken. But then again I'm not real sure where to look for that. When the truck cools down I will crawl back underneath it and give it a look.
Old May 16, 2012 | 04:53 PM
Papa Tiger's Avatar
Papa Tiger
You will probably need your tire jack and a block of wood to lift it up if the mount is bad. Don't put the jack on the drain pan though. It could be an idler on the surpentine belt is badly damaging things.
Old May 16, 2012 | 05:44 PM
Philipsterle
I just looked, and I couldn't see any place where the mount would be broken. It all seems intact and secure
Old May 16, 2012 | 06:04 PM
critterf1's Avatar
critterf1
Guts in the convertor rattling?
Old May 16, 2012 | 06:07 PM
Philipsterle
You know, I haven't thought of that. I first thought it was the CC but then it sounded like the tranny, how would I go about checking inside the converter?
Old May 16, 2012 | 06:30 PM
944_s_type's Avatar
944_s_type
+1 on an exhaust problem. when cool, give it a good shake.
Old May 16, 2012 | 08:31 PM
Philipsterle
Haven't checked yet, but if it rattles then what? If it doesn't rattle? How do I judge the results of this highly technical 'grab and shake' technique.
Old May 16, 2012 | 10:10 PM
Papa Tiger's Avatar
Papa Tiger
When youhave a bad vibration you need to use the process of elimination. See if there isa looxe broken exhaust hanger or hole in a muffler/pipe. Loosen the adjuster on the belt and see if there is a loose damaged drive on the belt. Then follow back along the motor to see if there is something laying loose along the frame in front of the driver, inside the engine compartment. Looki with a flashlight to eagle eye it. If you have bad drive shaft bearings it will throlw the assembly onto the street soon enough, same way with bad broke ball joints, soon the wheel will just break off.
Jamerian
Jan 24, 2021 01:02 PM
Dictys
1997 - 2003 F150
55
Apr 10, 2014 08:01 PM
danquin
Nov 21, 2007 01:50 PM
Schmids4.9l
Nov 12, 2004 10:12 PM
IRULE
Oct 5, 2003 02:10 PM
