Ignition resistance wire
Old May 16, 2012 | 12:59 PM
kjvforme's Avatar
kjvforme
I have a 62 ford f100 4x4 that I'm working on cleaning up the wiring under the dash. I found a wire that had burned of the insulation and was still connected. The wire in question is the resistance wire that went from switch to the coil, going through the bulkhead connector. The cloth wire protector was most likely the only thing that kept it going to ground and causing further damage to the truck. What shocks me was it was running, with out the insulation.
So where do I find a replacement for the wire, or can I buy a 1.3-1.4 ohm resister and solder it into the 20 gauge wire and call that good? I have alread pulled the wire from the bulkhead rubber connector so should be able to wire it in like original.
Your comments greatly appriciated.
Old May 16, 2012 | 01:20 PM
kjvforme's Avatar
kjvforme
Never mind I ran NumberDummies Motorcraft Dy-37 on the Napa parts interchange and they will have it to me tomorrow morning. Napa part number ICR22 Coil Resistor Ohms : 1.35 Ohms Ignition Coil Resistor Color Code : Pink
Old May 25, 2012 | 03:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by kjvforme
Never mind I ran NumberDummies Motorcraft DY-37 on the Napa parts interchange and they will have it to me tomorrow morning. Napa part number ICR22 Coil Resistor Ohms : 1.35 Ohms Ignition Coil Resistor Color Code : Pink
COLF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37) / Obsolete
61.49" long / Color coded pink / 1.30-1.40 ohms resistance / #20 gauge wire.
Applications: All 1960/73 FoMoCo vehicles.
Thipdar
Jan 29, 2018 11:21 AM
jxnslotcar
May 10, 2013 09:43 AM
4getmenot
Aug 12, 2011 06:28 PM
flipklos
May 29, 2009 08:32 PM
"Beemer Nut"
Electrical Systems/Wiring
Mar 5, 2007 11:52 AM
