risister wire problems over heats
Old Aug 1, 2011 | 10:44 AM
4getmenot's Avatar
4getmenot
bought a 1970 ford pick up with a late model engine 351 400m 1977, prob is how is the resister wire for the brain hooked up to the switch. At present is staying hot after it starts
Old Aug 1, 2011 | 11:13 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
This should help. Guessing it's Duraspark. It does stay hot electrically and will feel rather warm to touch also.
Old Aug 5, 2011 | 12:27 PM
4getmenot's Avatar
4getmenot
Thanks...the diagram helped alot.
Old Aug 12, 2011 | 06:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The resistor wire is the same with/without a "brain." There are two possibles for 1971/86's.
COLF-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-37).
61.49" long / Color coded PINK / 1.30-1.40 ohms resistance / #20 gauge wire.
D1AZ-12250-A .. Resistor Wire-Ignition Coil (Motorcraft DY-84A)
60" long / Color coded Red with Green stripes / 1.30-1.40 ohms resistance / #16 gauge wire.
Thipdar
Jan 29, 2018 11:21 AM
672wd72highboy
Jun 18, 2014 06:53 PM
kjvforme
May 25, 2012 03:33 AM
1972-34ton
Jul 14, 2008 03:30 AM
ReverendMachine
Feb 20, 2008 12:37 PM
