1978 - 1996 Big Bronco
headlight restoration
Old Sep 27, 2012 | 08:18 PM
  #31
roosplash's Avatar
roosplash
I used one of those Harbor Freight kits on mine without any success cause the polish they give you is too fine to cut the haze. However.... I used their drill adapter and sponge thing with some standard tooth paste and it cleaned them beautifully!! They have been clear for over a year now without any complaints
Old Sep 27, 2012 | 08:41 PM
  #32
greystreak92's Avatar
greystreak92
And left the headlights "minty fresh" at the same time!
Old Sep 27, 2012 | 09:03 PM
  #33
Big_Rob's Avatar
Big_Rob
which one? whitening? baking soda? mint? or regular???? :-)
Old Sep 27, 2012 | 10:17 PM
  #34
1_ton_bronco's Avatar
1_ton_bronco
I was gonna try this.. but it didnt make sense since they were gonna get cracked or scratched..
Old Sep 28, 2012 | 05:07 AM
  #35
GruesomeJeans's Avatar
GruesomeJeans
I do have a question on the topic. If you were to clean the headlights and do the sanding part, could you apply a layer of clear coat to prevent cracking from road debris? Or would that distort the light too much?
Old Sep 28, 2012 | 10:05 AM
  #36
1_ton_bronco
I had that in mind too.. Clear coat would burn off a little bit.. maybe
Old Sep 28, 2012 | 09:20 PM
  #37
roosplash's Avatar
roosplash
I used standard Crest toothpaste. Not the gel type. I did however cut of the 3 or 4 "nubs" that stick out off the lens. They get in the way . I used side cutters to nip them of, then a razor blade to get them as close as I could then sanded them smooth. The kit comes with a fine grit sandpaper for the initial step, then go to the toothpaste.
rblank
Jan 28, 2019 09:08 AM
PRO49FORD
Aug 11, 2015 08:03 AM
2007stlFX2
Ford Truck Parts for Sale
Aug 27, 2013 10:19 PM
nighthawk285
33
Mar 29, 2009 02:06 PM
7.3 Rocket
13
Jan 4, 2009 09:44 PM
