I would like to know this also. I had to use this while on a road trip and wasn't sure if it was ok. I'm thinking its fine because of the low percentage.
Several months ago someone posted some lab results for various fuel additives. The bio blend (5% IIRC) posted some good numbers for lubricity. Comparable to the old higher sulphur diesel. I don't remember all the details, but I decided the b5 was BETTER than dry ULSD.
Yup, it's fine. Like some mentioned it has better lubricity than reg ULSD with most additives. Be careful in the winter though as Bio blends usually gel up easier in cold weather.
Keep spare fuel filters handy because bio is a better solvent than dino diesel. It will dissolve crud out of the fuel system and the filters will catch it.
I fuel up in Grande Prairie Alberta today, it says, it may contain 5% biodiesel, it should be OK, we are in petrole contry and it was a commercial truck fueling place. Like you said, it will lubricate a little more, do not know about efficiency.
100% Bio is less efficient than petro diesel, Less BTU but a lot more Cetain. at a 20/80 blend you should not see hardly reduction in fuel economey.....
#2 diesel 140000 btu
100% bio 130000 btu
20/80 blend 138000 btu all per gallon
The only issue here is that you need to stick closely to the "severe service" oil change intervals.
HUH???
It seems that the combustion by-products of biodiesel, when absorbed by the engine oil and then transferred to the fuel injectors, makes the injectors not play nicely. The oil side of the injectors can get gummed up. Not a warrantable failure.
5000 miles (or less) on the oil changes if you run biodiesel.
However, the FUEL side of the injectors LOVES biodiesel. It runs quieter and more smoothly.
Just note that since the 6.0's fuel system isn't fully heated, biodiesel can be EXTREMELY problematic during weather below 35 degrees. Not only does it absorb much more water, but it gels at a much higher temperature. Be prepared to treat it much more heavily with anti-gel in the winter, even if the pump says it's already treated.
HUH???
-blaine
My only knock against Biodiesel is it's bad affect on spool valves. As Blaine said, you have to be much more proactive on oil maintenance, but the fuel side loves it.
