Sponsored by: Auxito
missing at an idle
Old May 14, 2012 | 07:37 PM
bussell2007's Avatar
bussell2007
missing at an idle
it's missing at an idle and it acts like it dont wanna take gas but once you get it going on the road it does good. the motor is a remanufacture motor it's only got 6,000 miles, new coils, plugs and wires, cam sensor, crank sensor, idle air control, mass air flow,and temp switch. If you have any suggestions on what the problem could be please let me know thank you.
Old May 14, 2012 | 07:46 PM
critterf1's Avatar
critterf1
What are we working on?
Old May 14, 2012 | 07:59 PM
bussell2007
1997 f-150
Old May 15, 2012 | 12:56 AM
Bluegrass 7's Avatar
Bluegrass 7
What motor are you working on?
4.2 v6, 4.6 or 5.4 v8!
Are there any codes set?
Old May 15, 2012 | 07:54 AM
bussell2007
it's a 4.6 and the only code it shows is the o2 sensor but it's got a new one in it
Old May 15, 2012 | 11:39 AM
critterf1's Avatar
critterf1
Which O2? Problem in the "circuit".
Old May 15, 2012 | 11:55 AM
Bluegrass 7
What is the code?
You don't change the sensor for the code unless the code say it's heater circuit is in fault or some direct sensor fault.
The codes shown are the only way the system has to tell about faults with other areas of the motor involving fuel and air.
If you want help, stop being so tight with info and tell it all.
It as taken 6 replys to even get this far and still we have nothing to go on other than what motor you have and an Ox sensor 'issued' code.
Old May 15, 2012 | 08:19 PM
bussell2007
the code was the heated o2 upstream but we replaced it.
Old May 15, 2012 | 09:42 PM
Bluegrass 7
I give up!
Old May 16, 2012 | 01:14 PM
bussell2007
ok thanks for your help anyway.
mainefordman
1997 - 2003 F150
Jul 11, 2015 08:39 AM
ledfoot
Oct 9, 2007 03:38 PM
ChiliPalmer
Aug 24, 2004 09:02 PM
Bryan Whited
Nov 28, 2002 02:25 PM
