Very soft brake pedal!
Old May 14, 2012 | 05:17 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
yes LSO, you will/should have rear abs.
Old May 14, 2012 | 07:06 PM
LSO1123's Avatar
LSO1123
I didn't know that, learn something new everyday!
Old May 15, 2012 | 01:07 AM
tecgod13's Avatar
tecgod13
Look on the drivers side frame rail under the front of the cab for the RABS unit.
Old May 15, 2012 | 01:55 AM
Aune163rd's Avatar
Aune163rd
its a goofy looking manifold with all the brake lines coming out of it, my brakes are great....i step on them and I dont get a sinking or anything, but my RABS light is on....what causes this lol?
Old May 15, 2012 | 03:17 AM
LSO1123's Avatar
LSO1123
I don't know but after bleeding all the brake lines today, my park brake light is staying on now! WTF?? Oh well, at least the truck stops when I want it to! I've got the truck and a 16' trailer loaded down with scrap metal right now so I'll see how it does when I haul it off tomorrow.
Old May 15, 2012 | 05:44 AM
hookedondiesel's Avatar
hookedondiesel
That light also tells you when your out of fluid.
Why it's on now, I believe, is your master ran out of fluid while you were bleeding it.
Here's an Excellent thread on the subject at hand.
Read the whole thread for how this problem was solved.
https://www.ford-trucks.com/forums/5...e-dilemma.html
Old May 15, 2012 | 02:20 PM
batchman's Avatar
batchman
if you are setting still holding the pedal down like at a stop light it will slowly go down almost to the floor. If the truck is not running and you good the pedal down it will not do this and stays firm. This leads me to lean toward the booster?
With the truck not running repeat this test with both feet pressing on the pedal with all you've got. My bet is it still sinks.
What I'm hearing here is:
- booster works (difference running vs not)
- master cylinder is bad (leaking down)
One other thing to check with the age of these trucks is the rubber lines. When they degrade they can swell with pressure.
Just my humble opinion!
Good luck,
- Jeff
Old May 15, 2012 | 03:15 PM
LSO1123's Avatar
LSO1123
I'm setting in the truck right now. With it not running, with both feet and all of my 180 pounds, I cannot make the pedal sink down to the floor. With it running, the pedal will stop up off of the floor then gradually sink on down.
Old May 16, 2012 | 09:05 AM
'94IDITurbo7.3
so i read that break dilemma thread. is the bigger MC the one with the 1 1/8" bore?
i looked at mine and i have the 1 1/8" MC.
Old May 16, 2012 | 12:06 PM
38Chevy454's Avatar
38Chevy454
If the pedal sinks under light pressure, that can indicate a bad master cyl. It is leaking back and usually shows up as brake fluid leaking down the back where it bolts on. Check carefully for fluid, it might be going into your booster instead of leaking down.
Even new master cyl could be bad, unfortunately. Easy enough to unbolt it and pull it away a slight amount to see if any fluid.
The brake light being on could be your proportioning valve is uncentered. There is apiston the floats between the sides and if it gets too far off center, it will set the light. See the small wire connected to it? That is what causes the light.
Old May 16, 2012 | 09:26 PM
LSO1123's Avatar
LSO1123
The brake light issue is fixed, me being the retard that I am forgot to add more brake fluid after I got done bleeding the lines. It wasn't empty but it was down to the sensor. It went off when I filled it back up. If it was the master cylinder leaking off, wouldn't it do it just the same without the truck running? I have a new booster and I'm gonna put it on tomorrow and see if that fixes the problem. I'll report back.
Old May 19, 2012 | 05:37 AM
hookedondiesel
LSO, I just recently did my brake's....
The pedal was good but the reason I did them was, (and this is a newly purchased truck that the guy told me the brakes were just done, crap)
when I stopped, my rear wheel was smoking. The wheel cylinder had a small leak, from inside the rubber cup, nothing major, but had to be fixed.
I installed.....
All new hose's,x3
Two new rear wheel cylinder's.
Two new rear drum's.
New shoes for the back, front were 3/4 and working properly.
New brake lines, front to back.
Adjusted rear brakes.
Bled and re-bled the system.
Pedal would go to the floor. when running.
Pedal was hard when it wasn't running.
Re-bled, again
Still the same issue.
Re-adjusted the rear shoes, one more time, until the wheels had a drag on them.
Now, the brakes are almost back to normal.
I personally don't think it's your booster.
"IF" the rear's are adjusted properly and your absolutely sure there is no more air in the system, then I would do one of two things.....
Bypass the ABS, as was suggested, or replace the master, it may have been damaged if it went dry in "your" bleeding process.
In any case, you'll have to bleed again.
Old May 27, 2012 | 07:03 PM
  #28
'94IDITurbo7.3
LSO,
did you ever get that booster installed? if so did it do anything for the pedal?
Upnorthtruck
May 7, 2018 02:14 PM
alchemist1
Aug 2, 2012 01:03 AM
JTS1975
Sep 13, 2011 09:35 PM
soccersmom
23
Aug 14, 2011 05:31 PM
jakegypsum
Sep 28, 2000 10:21 AM
