Update: sinking brake pedal (not stinking)...
Old Jul 31, 2012 | 03:50 PM
alchemist1's Avatar
alchemist1
for a long time I've been wrestling with a slowly sinking brake pedal. No leaks anywhere, all relatively new components, lines, MC, WC's, and calipers. So I've been looking at the fluid levels in the MC and found the problem. It looks like over time, fluid moves from the larger reservoir for the front brakes (the one closest to firewall) to the smaller reservoir for the rear brakes. So the MC must have some internal valve failure. It's not an air thing - there is no air in my system. Interesting - this was a new Raybestos MC from less than three years ago, and fresh fluid.
Old Aug 1, 2012 | 07:42 AM
wdfp's Avatar
wdfp
If that doesn't cure it, I had the same problem on my powerwagon for years, after several MC changes I found out it was the vacuum booster letting the pedal slowly ooze towards the floor.
Old Aug 1, 2012 | 07:51 AM
alchemist1's Avatar
alchemist1
I don't think the vacuum booster shouldn't have anything to do with a sinking pedal. It gives symptoms of a hard pedal (when not working), because the 'assist' isn't there all the time. My experience with them...
Old Aug 1, 2012 | 07:54 AM
jim collins's Avatar
jim collins
A couple of my 79s had the power unit go bad and do that. But it sounds like you have a master cylinder problem,fluid should not transfer from one bowl to the other. The cheap parts made now days can go bad right after you instal them. I think you have a cylinder problem.
Old Aug 1, 2012 | 07:58 AM
fmc400's Avatar
fmc400
MSEE
If you have fluid moving from one side to another, then the MC is bad (more likely), or the proportioning valve is bad (less likely).
Old Aug 2, 2012 | 01:03 AM
GreyScar's Avatar
GreyScar
Internal seal leak in the MC.......
daddylee100
30
Jul 26, 2016 12:53 PM
john59923
Sep 18, 2012 08:02 PM
snaponprofile
33
Oct 14, 2010 12:31 PM
backyard_costomizer
Bronco II
Aug 23, 2007 08:03 AM
randymo
1978 - 1996 Big Bronco
18
Oct 8, 2006 06:15 PM
