straight axle swap
Old May 13, 2012 | 09:58 AM
biff86's Avatar
biff86
straight axle swap
I have a 95 f250 that I would like to swap out the Dana 50 for a axle out of a 01 f350. What do I have to do to make this work on my truck?
Old May 13, 2012 | 10:34 AM
rideracelivemx7's Avatar
rideracelivemx7
Most of the super duty trucks came with different gears. 3:73 was typical. In all honesty it would be easier to just find a same axel out of a 350 for your year. The super duty has different linkage for steering so I'm not positive if it's a direct swap.
Old May 13, 2012 | 10:47 AM
biff86's Avatar
biff86
The reason I ask is because I got the axle all ready and was not sure what modifications I need to make. The linkage is not an issue to me it all is shot anyway.
Old May 13, 2012 | 12:12 PM
cornbinder's Avatar
cornbinder
the o1 front axle assembly is not the same animal, that's why you should use a 97- down. you wouldn't take a dodge truck and put a ford motor in it because you had a ford motor laying around would u? it just doesn't make sense to do what your wanting to do. a 97 down swap is a bolt in affair. to each their own if that's what u wanna do though.
Old May 13, 2012 | 12:23 PM
biff86's Avatar
biff86
For one dodge suck. But good point. I figured that they were not that dissimilar. Well beside the metric bolt pattern. Thought maybe there was something that I could do with what I got and not have to buy another axle. I mean free is free.
Old May 13, 2012 | 12:30 PM
cornbinder's Avatar
cornbinder
i see your point, just trying to keep you from getting your self into a mess. i'd sell that 01 front axle assembly and put it towards a 97-down d-60. i need a d-60 also for my 94 f-250, as the 50 is shot and i don't wanna deal with it anymore. pete
Old May 13, 2012 | 12:38 PM
biff86's Avatar
biff86
Thanks for the input I figured I would ask because I was not sure and didn't want it to be a big pain. Plus I had heard about people liking to put the hole axle springs and all out of a 99-01 truck into the old body stile. That is what fueled the question.
Old May 13, 2012 | 03:14 PM
tjc transport's Avatar
tjc transport
i ain't rite
first off, the bolt pattern is different, so you will need to carry 2 spare tires, or convet the rear rear also,
second: the steering linkage is different,
third: the spring perches are in different places. so you will either have to move the perches, move the springs, or put it in with the springs twisted to the side by 3/4 inch.
forth: if i remember correctly, the universals are different, so you will need a custom driveshaft.
Old May 13, 2012 | 09:12 PM
1982_f150's Avatar
1982_f150
if you can find one, get one 91 and older. i got mine out of an 89, it has king pins as apposed to ball joints. it is still a direct bolt up, just make sure you have the same ratio
Old May 14, 2012 | 09:11 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Bonus to using a superduty one is tighter turning radius. Big down side is unless you have a 4.10 geared rear end and the F350 SD is 4.10, then you will have to regear one of them. As far as I know 3.55 and 4.10 were what the obs came with and 3.73 and 4.10 were the more common SD ones. Plus the lug patter is different but over on powerstrokenation there is a thread similar where I think someone had the front flange redrilled for the obs pattern.
Mike1
Sep 25, 2017 04:42 PM
bigjoef250
Nov 10, 2014 10:16 PM
Fabman54
Large Truck
Aug 25, 2014 08:08 PM
sharky
Aug 27, 2010 09:35 PM
MASSIVE460
Feb 1, 2008 12:39 AM
