Alternator / System Questions
Old May 29, 2012 | 07:29 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
Originally Posted by gsxr1300
i just found online the standard is 155 and extra heavy is 200
Makes sense cause i have dual alts and its 355 amps, so its one of each i guess
Old May 30, 2012 | 01:43 AM
Roamer105's Avatar
Roamer105
Originally Posted by Tuxedo Scorpion
has anyone checked the voltage output of their system while running? with/without a load?
Also does anyone with dual alternators know if there is any CEL type of indication if one fails?
Not sure about the CEL indicator, but definitively it will throw codes and potentially turn on the alternator failure light. With a dual alternator system, Ford uses the one on the passenger side as the "primary" and the optional one as a "secondary". What this means is that the primary will produce ALL of the necessary power until it reaches close to its generation capacity. At that point, the ECM will "turn on" the secondary alternator the assist/complement the primary. If either would fail completely, the other would take over but there would definitively be codes and possibly the alternator light on.
Old May 30, 2012 | 04:52 AM
dbc001's Avatar
dbc001
Tux ...... Rule of thumb is not to overload any part of the electrical circuit beyond 80% for a constant load. In other words for a 25 amp breaker and assuming the wiring is rated for 25 amp you should not present a constant load of over 20 amps. Do so and you risk overheating and possibly fire.
Putting the HD relays in the engine compartment direct connected to the battery and driving them from the upfitters is the wise way to do it. Keep the heavy current out of the cab where ever possible.
Old May 30, 2012 | 09:40 AM
mhoefer's Avatar
mhoefer
Isn't upfitter 1 And 2 30 amps or did they change it.? If so you are well within at 12 volts, even if your down to that, I would run off the upfitter. No need to do more.
Old May 30, 2012 | 09:51 AM
Tuxedo Scorpion
The heavy current is kept out of the cab either way because the upfitter relay is in the engine compartment.
That being said i doubt the manufacturer rate something at 25 amps with the expectation of only 20 usable.
Nonetheless i have about 15 amps on the circuit utilizing the factory relay and fuse
Old May 30, 2012 | 10:09 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Tux just an FYI the upfitter relays are right next to your left knee, inside the cab above the e-brake!
Old May 31, 2012 | 04:02 AM
dbc001's Avatar
dbc001
Tux.. electrical is not natively designed for a constant 100% load. Most "things" will vary in their current draw and not tax the system at a constant load. Exceptions to this are knowns like headlights and the electrics for them are designed not to exceed the 80% rule.
It's kind of funny actually because most mechanical engineering would over design and under utilize as an operational limit. Electrical world not always the case.
Old May 31, 2012 | 08:13 AM
JohnD333's Avatar
JohnD333
Tux,
Did you see how thin the upfitter wires are? Granted they are only running 2 feet or so from the relay, but you adding 10 feet of heavier wire to the front lights with heavy draw would turn that thin factory wire into a mini heater. That is what will pop the factory fuse. This the argument for thin wire to your own auto-reset relay underwood near the battery and a heavy wire from the battery to that relay and a heavy wire from the relay to the lights. To help put the draw in perspective, what wire size comes with the lights or is being recommended by the light mfg?
Old May 31, 2012 | 08:16 AM
Tuxedo Scorpion
It was 14 ga txl. So dont be fooled by the insulation...
Old May 31, 2012 | 01:32 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Overcurrent protection for 14ga is only good for 15Amps per the NEC.
The wire itself may be good for up to 20a but.............
Your truck.
Old May 31, 2012 | 02:47 PM
Tuxedo Scorpion
Your truck.
its 25 amps for cross linked polyethylene....aka XHHW
Electrical wiring in North America - Wikipedia, the free encyclopedia
and thin walled cross linked polyethylene is called TXL
Meets SAE J1128 and Ford Specifications....
Old May 31, 2012 | 03:49 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
In order to use the XHHW or TXL for anything above 15A the connector the wire is tied into must be 90 degree C rated no matter what the wire is rated for and you dont find connectors rated for 90 C much except in MIL rated equipment. In short the wire might be able to carry the amps but the connector it is tied to wont.
The NEC says overcurrent for #14 is 15A no matter the type. Up to you bro.
Old May 31, 2012 | 03:56 PM
  #28
Tuxedo Scorpion
a) the load on my circuit is 14 amps
b) all i use is 125c rated parts / equip, all Mil-Spec
Old Jun 2, 2012 | 11:33 AM
  #29
TRENT310's Avatar
TRENT310
I realized that building electrical code isn't taken into account when designing vehicle wiring harnesses. Check out the cigarette lighter/12V plug wiring on most vehicles these days.
There's the NEC general rules that we go by, eg. 14AWG = 15A, 12AWG = 20A, etc. which include a pretty huge margin for applicability in various situations, but there are ampacity formulas that take into account spacing between adjacent wires, ambient temperature, whether it's enclosed (conduit) or in free space, insulation type (eg. thermoplastic/THHN or thermoset/XLPE or cloth braid)... putting that all together generally yields higher wire ampacity for the same environment compared to following the rule of thumb which always errs on being safer.
I wouldn't say a vehicle interior is a particularly harsh environment where you have to derate everything... but we like overkill here.
Old Jun 3, 2012 | 06:54 AM
  #30
Tuxedo Scorpion
I ran all the ampacity calculations taking into account environment, insulation, bundling, length, wire type, etc,... and decided on exactly what was acceptable and what was not. I doubt many do go that far though. Oh, and im still way below the limit
heres a great link for circuit calculations:
http://circuitwizard.bluesea.com/
Supercab
Mar 27, 2018 10:28 AM
Tedster9
May 17, 2016 01:30 AM
afinepoint
Electrical Systems/Wiring
Oct 25, 2009 10:49 AM
greenwoodford
56
Oct 6, 2009 01:23 PM
big84ford4x4
Feb 3, 2004 10:33 PM
