CEL yay
Old Jun 3, 2012 | 09:27 AM
jggearhead's Avatar
jggearhead
CEL yay
Hey all,
Just got my first CEL i pulled the code p0401 I dont want to erase so i can get the truck into the dealer. Anoone have this issue before? thanks!
Old Jun 3, 2012 | 09:39 AM
sdetweil's Avatar
sdetweil
from https://www.ford-trucks.com/forums/9...l#post11335981
P0401 - Exhaust Gas Recirculation (EGR) Flow Insufficient Detected
Andrew010's Avatar
Andrew010
Old Jun 3, 2012 | 09:40 AM
Andrew010's Avatar
Andrew010
Quick on the draw Sam!
Old Jun 3, 2012 | 09:44 AM
jggearhead's Avatar
jggearhead
yup i know what the code means did anyone have this code and did they take it to the dealer for them to fix it?
Old Jun 3, 2012 | 09:50 AM
Andrew010's Avatar
Andrew010
Sounds to me there's either restriction in the up-pipe (from the exhaust manifold to the egr valve) or the valve itself it's working properly. Might be full of soot and not able to open and close completely.
If you didn't want to wait for the dealer you could easily remove the up-pipe and look inside the egr valve. Might be clogged and you could clean it out and problem solved.
If I remember right there 4 or 5 8mm bolts to remove the up-pipe. It's the same thing you would do to block off the EGR for tuning.
Scratcha
Modular V8 (4.6L, 5.4L)
Mar 4, 2014 11:58 AM
mrgn_mtt
Apr 17, 2011 10:21 PM
2010F350
6.4L Power Stroke Diesel
Oct 17, 2010 04:36 PM
ram10
Modular V10 (6.8l)
Mar 14, 2007 04:59 PM
hush210
Feb 19, 2007 07:48 PM
