94 f150 speedometer question
Old 05-13-2012, 08:32 AM
davido's Avatar
davido
davido is offline
I got in the truck yesterday and the speedo didn't work, or the odometer. The dome light was not working and the overdrive light is flashing on the shifter. Fuse problem? any ideas? I was checking fuses but they looked ok, it has to be a fuse. we had alot of rain for a few days.
Old 05-13-2012, 10:21 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
https://www.ford-trucks.com/forums/1...-question.html Have a look at the circuit diagram in this thread.
Old 05-13-2012, 11:47 AM
601ford's Avatar
601ford
601ford is offline
I had the same problem with a 94 F250 4x4 460 AT. It was a blown maxi fuse in the under hood fuse box. It happened again and I found a bare wire coming out of that box. I happened when it was raining/muddy. I fixed the wire and have had no problems since.
Old 05-15-2012, 04:18 AM
davido's Avatar
davido
davido is offline
Thanks. I'll let you know when I get some time off to check
Old 05-15-2012, 10:43 AM
doublebutted's Avatar
doublebutted
doublebutted is offline
I just posted a thread on this today! I have the SAME EXACT symptoms. First thing suggest was to replace the VSS. So I'm picking that up tonight and I'll let you know if that fixes it. Slow steps. I'm making sure I take care of the easy stuff before tackle something behind the dashboard. My dome light isn't working either. WE have the same exact thing going on. Here's my thread posted 5 minutes ago.
https://www.ford-trucks.com/forums/1...-of-stuff.html
Old 05-18-2012, 01:48 AM
davido's Avatar
davido
davido is offline
Glad to hear it's working now. I'll check #8 fuse. where is the VSS located.
Old 05-18-2012, 01:47 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
VSS is on top of the rear axle differential housing.
Old 05-18-2012, 01:49 PM
doublebutted
Oh mine, its on the rear differential. Just a quick turn with a 1/2" socket took it out.
Autozone guy said it was on the catalog as an ABS speed sensor. It should look like have a 90 degree bend to it.
Fixed the O/D light. Which fixed the shifting. Truck actually shifts gears now and I don't have to fill up the tank every couple of days
The #8 fused fixed a lot of problems for me. Buzzer, light that turns on when I open the door, odometer/speedo.
Old 05-19-2012, 03:13 PM
davido's Avatar
davido
davido is offline
Fixed now. It was the #8 fuse and I also changed the speed sensor on the rear end. Had the codes pulled and they said it was the speed sensor and it needs the o2 sensor replaced.
Old 05-20-2012, 02:58 PM
doublebutted
Oh, where's the 02 sensor?
Old 05-21-2012, 01:15 AM
davido's Avatar
davido
davido is offline
It should be before the cat. I'll order it from Rockauto.com
Old 05-21-2012, 08:43 AM
doublebutted
Follow up on how hard/easy this was. I don't mind replacing a bunch of stuff on my truck because who knows when anything was replaced. Original owner didn't even know when he changed the oil and he had the car for 2 years.
77_150
03-13-2015 03:53 PM
Jasonpremo
11-20-2013 07:19 PM
Builtihtuff
08-09-2012 07:40 PM
jvanderman
09-16-2011 03:36 PM
rcaryl
01-05-2005 09:26 PM
Quick Reply: 94 f150 speedometer question
