97' 460 running hot!
Old May 20, 2012 | 07:44 PM
builder102's Avatar
builder102
97' 460, in my F-250, gets so hot, you can't touch the return Rad. hose. But temp. gage is on the "N" in Normal at water tenp gage! Where do I start, already change the thermistat, and water pump! Help!!! And has new Radiator!
Old May 20, 2012 | 09:12 PM
kd0axs's Avatar
kd0axs
Normal means normal, nothing is wrong if it's in the normal range. The hose is supposed to be hot.
Old May 20, 2012 | 09:41 PM
Kdr358's Avatar
Kdr358
It's a 460 they run hot, the hot hoses are normal my 7.3 you can't even touch when the truck is hot. In my 70's demo cars I dry block the motors and trust me they have no problems dealing with heat. Lets put it this way I've gotten a 71 Lincoln mark 4 460 so hot you can smell and hear the oil sizzling out of the motor. Your in good shape !
Old May 20, 2012 | 10:39 PM
9402fordguy's Avatar
9402fordguy
I believe the 460s use a 190* or 195*F thermostat... you won't want to touch anything after the truck is up to proper operating temperature. As long as the temp is registering in the 'normal' range you are good to go. If it gets too hot the fan will kick in and it will sound like you are driving a Kenworth!
Old May 21, 2012 | 07:55 AM
powerstroke72's Avatar
powerstroke72
Moved to correct forum.
Old May 21, 2012 | 08:52 AM
Lead Head's Avatar
Lead Head
The temperature difference across the radiator is only going to be around 30*F, maybe 40*F if you have a really good, clean radiator and a perfect fan clutch.
With a ~190*F thermostat, that means you can still expect 150-160*F on the lower rad hose - which will still burn you.
If its not pushing coolant into the overflow bottle/boiling over, and the gauge reads normal - it's fine.
Firefighter12
17
Sep 8, 2015 06:46 AM
46069dord
Jan 17, 2008 08:18 PM
John Rowe
21
Feb 10, 2006 10:56 PM
2tweak
28
Sep 15, 2003 07:32 AM
dave98
Apr 26, 2003 11:24 AM
