starter problems?
Old May 12, 2012 | 09:32 PM
Skape's Avatar
Skape
starter problems?
Hi everyone,
I have a 1996 F250 PS 7.3. The alternator seems to be charging according to the dash gauge. I did notice the battery light would appear and after reading another thread I wiggles the wires and it went out, I recharged the batteries and now it seems to crank slow, then now it will just click and wont turn over. any ideas on this?
thanks
Old May 12, 2012 | 10:07 PM
fordpride's Avatar
fordpride
Clean and check all battery connections even at the starter
Old May 13, 2012 | 05:17 PM
yoslick's Avatar
yoslick
The cable (+) that goes from one battery to the other is famous for rotting from the center out. Are yours original??
Old May 14, 2012 | 08:49 AM
Skape's Avatar
Skape
The fix
Thanks for all the ideas, after checking all the cables and cleaning the ends I did notice the + cross over cable had some corrosion under the insulation, we tried usinf a heavy set of booster cables to make a better contact but still no luck. I had a friend lay down looking at the starter while I remote triggered the selonoid, he decided to tap on it lightly with a piece of wood and there it was!, sparks started to fly and the starer engaged. the problem ended up being the wire NEXT to the main + cable terminal on the starter, we took the old nut off carefully and bought a new 5/16 nut and re tightened it down, starts like a champ now.
Again thanks for the posts
Dave
Troy conrad
Jun 23, 2019 11:09 PM
dominick2006
Oct 31, 2015 02:01 PM
Arizcoin
Apr 7, 2013 08:27 PM
BigBlockF350
27
Mar 17, 2013 08:22 PM
rosa70
Oct 5, 2004 11:09 AM
