Bad Gas?
Old May 12, 2012 | 07:54 PM
Lumberjack PAT's Avatar
Lumberjack PAT
Question Bad Gas?
So I have a 1986 Ranger 2.9 L 2WD Auto. It starts fine, runs good, but all there is, is a huge flume of bluish/white smoke that keeps coming from the tailpipe. I'm thinking it's bad gas... (it sat for a good while) It does seem to hesitate when I rev it up in park as well. Also there seems to be a little ping in it, very small, low ping. It runs up and down the road fine. Just confused here. Friend suggested that there might be a crack in the engine... I do know that the valve cover gaskets are needing to be replaced as well as the spark plugs I assume. Also said that it might be an O ring.
Any Help in much appreciated.
Patrick
Old May 14, 2012 | 01:30 AM
jacks61ford's Avatar
jacks61ford
could be bad gas how long did it sit if over a year don't run it on that gas no more as it could varnish up the valves causing them to stick if not been sitting that long run a compression check could be a bad head gasket between two cylinders
Old Jun 13, 2012 | 08:47 PM
Beanscoot's Avatar
Beanscoot
It's unlikely to be bad gasoline if it runs well. You probably have either oil or coolant getting into the combustion chambers.
Does the exhaust smoke smell sweet, like antifreeze?
Heavy oil burning will produce white/blue smoke. Oil can get into the combustion chamber from bad valve guides, broken or badly worn piston rings, a faulty transmission vacuum modulator, clogged drain back holes in the cylinder head, a faulty PCV system or simple overfilling of the oil sump.
What's the history of this vehicle?
Ray77F150
13
Jun 26, 2014 01:55 PM
77 2wd
Nov 4, 2012 07:03 AM
8525ford
May 4, 2010 04:43 AM
BlueTorpedo85
21
Aug 22, 2006 01:17 PM
dwayne93
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 17, 2004 05:37 PM
