Assembly Mastic / Caulking Between Panels
Old May 12, 2012 | 07:25 PM
turnrjr's Avatar
turnrjr
What have you guys used to replace this material when you reassemble?
Old May 12, 2012 | 07:31 PM
AXracer's Avatar
AXracer
You can buy the caulk in packages of strips in the insulation dept at the DIY stores, rec vehicle parts stores or at auto parts stores. It has a putty like consistency that never hardens and is only slightly adhesive so it can be taken apart and cleaned off clean.
Old May 12, 2012 | 07:42 PM
turnrjr's Avatar
turnrjr
That sounds like the original mastic. When I first looked at that clean up job I thought this stuff is going to come off hard. I was pleasantly surprised. After 58 years it scraped off cleanly once it sat in the sun for a half hour.
Old May 12, 2012 | 08:09 PM
AXracer's Avatar
AXracer
Yep, that stuff has been around a long time because it works better than anything else.
Old May 12, 2012 | 08:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I think it was on the HAMB, in a Tech thread, that a guy used a bead of polyurethane sealant on the tunnel cover, put saran wrap over it, then pressed the cover into place. He let it cure, then removed the saran wrap. Instant permanent (more or less) re-useable gasket. (I can't remember if it was saran wrap or waxed paper)
Old May 12, 2012 | 09:24 PM
tinman52's Avatar
tinman52
Welder User
Strip caulk.....
Available at NAPA or any good parts store. Not autozone.
Old Jun 15, 2012 | 09:16 PM
tiredolbiker's Avatar
tiredolbiker
Try the mastic used on metal roofs, it's awesome.
Old Jun 16, 2012 | 01:24 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle
You are joking right? My experience with that, sticks to everything then oozes through everything, good for tracking everywhere, won't come off clothes, hands, or mosquito's on a bald head!
Old Jun 16, 2012 | 08:38 AM
oldmerc's Avatar
oldmerc
oldmerc
Jeff you have described "that stuff's" design specs to a T .
Old Jun 16, 2012 | 07:35 PM
tiredolbiker
The "stuff" I'm referring to comes in rolls ,usually 3/8" wide. It does not run or ooze out. It is used between the laps on metal roofing, It does not harden and is relatively easy to get off if its warmed up a little. It was designed to go between layers of metal to form a waterproof seal. The bead of polyurethane sealer you referred to earlier is probably the same thing
Old Jun 16, 2012 | 09:44 PM
old ugly's Avatar
old ugly
Hi all,
This is what I have been using. It seems very close to original material but it is a Canadian product so don't know if it would be available in the U.S. Got it at the local Home Hardware store, very inexpensive.
I have also seen similar material used in semi trailer vans that came in fairly large rolls about 1/4 '' wide. Could possibly be available from a place that repairs these trailers.
Curated Content Editor
General Automotive Discussion
Jun 20, 2017 03:50 PM
SeaCarr
Oct 11, 2015 06:49 AM
tlzkaasen
Oct 26, 2009 06:30 PM
51PanelMan
22
Apr 15, 2007 10:43 PM
F150daniel
May 21, 2003 10:58 PM
