hey guys do any of you guys have the 20x9 xd hoss w/-12 offset installed on your leveled 2011 f350's?? tires ill be running are nitto trail grapplers 35/12.50r20's. seems like +18 are working but i was hoping to see the -12 offset??? please post pics or let me know the advice!!! and is there any tire rubbing??
dang i was way off. plus 40 holy cow. no wonder the 0 offset 20x9s wont work on my stock set up
Why won't it? You'll need a leveling kit for 35s, but that has nothing to do with the wheel offset. With a 33" or 34" tire you won't have any problems.
That wheel will stick out roughly 2.25" further than the stock wheel. Mine stick out 3.5" further than the stock wheels.
You should not need a leveling kit for 35" tall tires that you mention, I ran them for about 2 years and NEVER hit anything. I ran the BFG AT's so some tires are bigger than others and it does seem that BFG's always run a bit smaller than advertised.
As far as rubbing goes it will depend on the tire width. I have just gotten my new Nitto Terra Grapplers in 295/60/20 which is actually 11" wide and 34.6" tall. They do rub just a little bit but I can't feel it in the wheel but it shows a slight little wear spot.
I have the Readylift 2.5 level kit, 20" KMC Misfits, and 35/12.5/20 Toyo Mt's and have no issue. Only very seldom when turned all the way over and the friont tire hits a big bump. And even thens its just a very little rub for second.
