Anyone running 35 or 37 on stock 20” wheels?
Just about time to get new tires. Trying to decide between 35s and 37s. I was looking at pics in the 6.4L thread. Quite a few guys posted some good looking rigs. I have a ‘16 with the fx4 factory kit. Local shop said leveling front and 35 would work with zero offset. Anyone have pictures and experience they can share with factory 20” rims?
My 285/65 measure 35.8 x 11.4...They have a heavier rating than the actual 35's. I see in other threads on here,a lot do run the 295/65 with no issue....on stock rims, it is wise to check tire makers dimensions. If you are going to Tow/ Haul....any amount of weight, I personally wouldn't go to 37's. You should be fine with stock rims. If you send me your cell....I will send you pics that way if you want.
Yes. I have run 35's and 37's. I posted several pictures of all the different set ups I have had on my truck in your other post.
https://www.ford-trucks.com/forums/1...tire-size.html
04SilverSCFX4
2004 - 2008 F150
21
03-01-2005 03:01 PM
