steering/Shift column diagram
Old Nov 26, 2006 | 08:17 AM
93f350's Avatar
93f350
hey everybody, just wondering if anyone knows where i can get a diagram of the shift lever area for and auto trans 93 f350 diesel?? my lever "broke" and i only have R-N-D, very sloppy, just wiggles up and down until i move to put into gear. i can not get into any other gears...i'm asking about to look at a diagram because i;m not familar w/ this column, so please if you know any info hit me up, thanx
Old Nov 26, 2006 | 08:32 AM
mississauga's Avatar
mississauga
I think most of the dealer parts departments will give you a print out of the parts diagram for the area you are talking about which is generally pretty good. It should at least give an idea of what is in there.
Old Nov 26, 2006 | 10:06 AM
Rusty_Spurs's Avatar
Rusty_Spurs
I had a very similiar problem with my 1996 F250. I took the cover plates apart, and starting seeing more and more stuff either lose or broken. I then grabbed what I knew was broken and headed to the local pull it yourself junkyard. This away I could see how it was installed and how it looked myself. Just a suggestion, but mine is working great now. No more problems. I have heard that this is a common problem. Good luck.
Old Nov 26, 2006 | 10:13 AM
frederic's Avatar
frederic
custom1106
Mar 30, 2014 02:33 AM
jeff14346
Jan 2, 2012 05:43 AM
Daviddc114
Mar 20, 2011 08:30 PM
learpilot
Jul 13, 2009 05:33 PM
Heatnbeat
Dec 27, 2006 09:39 PM
