Sponsored by: Real Truck
Torqueshift slippage
Old May 12, 2012 | 03:15 PM
DieselVol's Avatar
DieselVol
I was told once that slippage in the transmission feels like driving in sand. Well, my '03 F250 feels just like that every time I start off. I've noticed no revving of the engine and it seems to be no different whether pulling heavy or just driving empty. Is this feeling likely a slip? Does it mean the transmission is going out? Is there something I need to do to prevent this? Thanks.
Old May 13, 2012 | 06:43 AM
DieselVol's Avatar
DieselVol
To clarify, it sort of feels like the back tires slip some even though it's on dry pavement. I suppose it could be in the limited slip rear end, but this is the second limited slip I've had in it this year and this problem was the same before and after the change. Any thoughts?
Old May 13, 2012 | 10:39 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the transmission is slipping the ATF is going to be brown or black. If it isn't slipping the fluid will still be red.
Old May 13, 2012 | 11:01 AM
DieselVol's Avatar
DieselVol
[QUOTE=Mark Kovalsky;11826719]If the transmission is slipping the ATF is going to be brown or black. If it isn't slipping the fluid will still be red.[/QUOTE
Mark, I was hoping you'd weigh in. Thanks for sharing your expertise.
NinthGenF-SeriesOBS
Apr 20, 2016 05:50 PM
aocabrown
Feb 9, 2009 04:33 PM
mia
Apr 10, 2007 08:52 AM
Dsl Lover
Nov 30, 2006 12:30 PM
trike1946
May 19, 2006 06:46 PM
