SGII GOOD MAF Volts Gauge (X-Code Inside)
Old May 12, 2012 | 12:58 PM
BLADE35's Avatar
BLADE35
Do any of you guys have a SGII MAF sensor Code
For either MAF VOLT GAUGE or MAF PSI(kpa)Gauge
I feel pretty confident SGII will read it
ANYONE????
I just know we already see Half that sensor already with IAT1 but havent seen a MAF gauge
Old May 12, 2012 | 10:03 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I posted a note to James. We will see what He can come up with. Hopefully both!
Old May 12, 2012 | 10:56 PM
BLADE35's Avatar
BLADE35
Thanks Sean
James hassnt been on the PSNation since last year
Old May 14, 2012 | 10:59 PM
BLADE35's Avatar
BLADE35
Heres a Bump for this thread
Sean let us know when If you hear from James D
I didnt think anyone had a MAF Gauge going for SGII so hopefulley will get one figured out
Old May 15, 2012 | 03:25 AM
Yahiko's Avatar
Yahiko
When you find it I would like to try also
Thanks
Sean
Old May 15, 2012 | 07:33 PM
BLADE35's Avatar
BLADE35
How ABOUT A FPW GAUGE or X-CODE for SGII
Does anyone Have a FPW Gauge that seems to Work Right????
In my truck at KOEO I am getting a FPW Gauge Reading
IMO at KOEO a FPW should be 0 (IIRC I got like 600 or something I know is Bad reading)
Whats codes you guys using that work better than what I have I just Noticed this
Trying to get a MAF & FPW Gauges Dialed In
Old May 15, 2012 | 08:52 PM
amdriven2liv
Here is a MAF code from Scangauge II to try.
Mass Air Flow (Gram/S)
TXD: 07E0221671
RXF: 046245160671
RXD: 3010
MTH: 000100010000
NAM: MAF
Not sure about the FPW. Do you have it? To give here.
Old May 15, 2012 | 09:02 PM
Roasted7's Avatar
Roasted7
What is FPW?
Old May 15, 2012 | 09:07 PM
BLADE35's Avatar
BLADE35
TXD: 07E0221671
RXF: 046245160671
RXD: 3010
MTH: 000100010000
NAM: MAF
Thanks agian Sean PM Sent
I really appreciate Your Help to git this Sean And tell James D thanks From the Boys here at FTE to you guys are Great
I have a FPW Gauge But I dont think its spiting out the right Number Im going to check the FPW Gauge tommorrow and this New MAF gauge out and see whats up with them If I run into some BS with them I will let you know and see what the best fix is Sounds like James D is still All over Helping us make a couple more Gauges So with everyones help hope to get the rest these Gauges Dialed in
Thanks again Sean and James D if your out there
Old May 15, 2012 | 09:19 PM
BLADE35's Avatar
BLADE35
Here is the FPW X-Code I have
Fuel Pulse Width=
FPW Fuel Injector Pulse Width (microseconds) TXD: 07E0221410 RXF: 046205140610 RXD: 3010 MTH: 000800010000 NAM: FPW
You guys try this code and see what you think^^^^^^^^^^^^^^^^^^^^^^
Im not shure if this is the one I have programmed into the SGII or Not I will verify the Code in the AM
But am curious to see what you Guys Get
AT KOEO FPW should be 0
and at KOER should be a Value hold on a sec
FUELPW 0 990 680 0 - 50000 (μ seconds) Fuel Pulse Width
and MAF should be
I didnt see one for Grams IDK in the operating Values we gotr from Cheezit
I saw one for MAF Volts I was hopen that he would give us the MAF Volt one and maybe he did will enter it in 2 morro and see what he gave us
Old May 15, 2012 | 09:54 PM
BLADE35's Avatar
BLADE35
Originally Posted by Roasted7
What is FPW?
Fuel Pules Width=FPW
these are usually Millisecond measured Injector On time
The FICM will Command inject cylinder 1 or MORE times per Stroke
It will inject fuel to reach the MFD or (Mass Fuel Desired)
But Im using it to check the FICM fuel Injection Driver basicaly
cuz there are 2 sides to FICM per say the Power Side (48volts and 12Volts) and the Injector Driver side (Driverside Controls the Injector spool Valve)
This may help diagnos things more with SGII but keep in mind Ford IDM or AE with ford enhanced bundle is still better at Inject diagnostic
Old May 16, 2012 | 08:08 AM
amdriven2liv
First start.
Fwt is 69
eot is 69.9
idling these temps
MAF o.15
FPW 1228 and dropping as warming up.
Kicked on the high idle switch. 1200 rpm
MAF 0.27
FPW 944.
More as day progresses.
Old May 16, 2012 | 10:04 AM
BLADE35's Avatar
BLADE35
I did find 2 codes for FPW so Have to sort threw them
Sean them readings seem Good
I just can find a value for MAF Grams IDK let you guys know tonight
Old May 16, 2012 | 06:57 PM
amdriven2liv
Ok,
Low HOT idle:
MAF 0.09
FPW 1104 (fluctuates, tough to give accurate reading here)
High HOT idle (2500 rpms or as close as I could keep it.)
MAF 0.47
FPW 647 (fluctuates, tough to give accurate reading here)
60 MPH level ground:
MAF 0.45
FPW 1360 (FPW fluctuates, giving average here)
75 MPH level ground:
MAF 0.62
FPW 1176 (FPW fluctuates, giving average here)
Fuel Pulse Width values:
FUELPW
KOEO 0
Low idle= 990
High idle =680
Operating range=0 - 50000 (μ seconds) Fuel Pulse Width
Also, FPW goes to zero while coasting down hills.
Old May 16, 2012 | 09:02 PM
BLADE35's Avatar
BLADE35
Sean My MAF was at 41.0 and when Id Get into it WOT 43.3 or so
Sean the Decimal Point is Off a Digit IDK if it My Code for MAF or Not
Gona have to double Check MAF Code Your Numbers and I cant Say one way or the other yet
Im still lost with his MAF Gauge though is it Grams per Minute or Second or IDK just think about it
Ultimatly If we got a MAF Volt Reading Gauge that would do us more GOOD than Grams Gauge for MAF. IDK if we can Find a Operating Value For MAF Gram
We DO have an Operating Value for MAF Volts though so this way Im thinking Volts would be better
At least right now we can Seee the MAF Gauge Kinda Work
Now I did some messing around and Could NOT get a CMP/CKP SYNC to come off 0
But I did Get FICM SYNC 1
NOW for the KICKER Here when I have Ficm Sync and CMP/CKP Sync both displayed at the same time the CMP/CKP wont give a reading If I change the ficm sync to another Gauge then CMP/CKP will show 0
Basicaly what I mean here^^^^^ is them 2 gauges act just like it would if you Put EOT Gauge up Twice but ONLY 1 GAUGE will display
so I find this ODD that FSC and CMP/CKP Sync act the same as above^^ its like they both are Looking at the same PID
Want to run these X-Gauges for a couple days and see before You Email James AGAIN Sean I got a couple things I think we should run by James D Few Days from now first next week or so after we run these Gauges and get a feel for them
Plus I want to see what ALL the rest of you Guys Get
What Codes you Guys Using for FICM Sync and for CMP/CKP Sync????????????????????
