Bearing help needed
Old May 12, 2012 | 09:48 AM
mckbooger43's Avatar
mckbooger43
Bearing help needed
I am going to rebuild my front end. It's a 44-6cf low pinion disc brakes 4:10 gears. it has the big bubs that bolt on. Does anyone have the bearing numbers inner and outer. Your help will be much appreciated. Also the driver side and wheel stub were taken out and destroyed. Where can I get another. And I can't turn the yoke by hand its pretty stiff. Could it just be the bearings in the pinion.
Old May 12, 2012 | 11:48 AM
Pickupmanx2's Avatar
Pickupmanx2
Hey Booger,,,, First off,, the year make model would help,, I am guessing an F250,, but the more info the better,, and head to a local NAPA,,, they can get most anything for these older piles,,, and as for the axle,,, junk-yard,,, or upgrade both with aftermarket stronger units,,,
Joe
Old May 12, 2012 | 07:12 PM
mckbooger43
Its a 1974 f250 but the axle is out of a 1976. I have no idea what I can upgrade too. I have a divorced transfer case.
Old May 12, 2012 | 08:46 PM
HIO Silver's Avatar
HIO Silver
Get the BOM number off the axle and look it up in Dana's catalog -third from the bottom on this page: Dana Holding Corporation The Expert Librarian - Information for driveshafts, u-joints, axles, heavy axles, light axles, Drivelines
1950FordF1
Mar 21, 2016 06:13 AM
20015.4f350
Jul 18, 2014 11:15 AM
thrifty
Jun 6, 2011 11:53 PM
whdahel
May 28, 2009 11:08 PM
shu5720
May 20, 2008 04:05 PM
