Number dummy axle bearing # or kits?
Since you have a bearing, any reasonable auto parts store should be able to cross-reference that and provide you with a new bearing and matching retainer, seals, etc. If they're really good, they might even be able to press the old one off and the new one on your axle shaft. You'll need that done, too, unless you're unlike most guys and actually have your own press in the corner of your garage. ;-)
I gave the # to the guys at Napa and they told me there are 8 or 9 possibilities. Problem is the guy that I took it to had to cut the bearings off. He did not have the right attachment for taking it off with a press. All I have is the number for that bearing. The other bearing that he took of had a plastic carrier. Not really to excited about using one of those. I just thought if he knew what to cross reference with it would be easier. I have the inner part of the bearing, and also know what the outside bearing size is. I have a Diff. shop looking for the numbers. I am trying to get the best bearing possible.
Thanks
Thanks
trevorrules
08-09-2013 05:23 PM
JackOfAllTradesRuss
04-15-2010 01:05 AM
slpin
09-12-2006 11:57 PM
