Engine Exchange
Old May 11, 2012 | 07:46 PM
Poolguy601's Avatar
Poolguy601
Engine Exchange
Will a 7.3 from a 2003 4x4 Excursion drop into a 1997 F250 4x4? The F 250 has a 7.3 turbo in now.
Old May 11, 2012 | 08:27 PM
F350-6's Avatar
F350-6
Yes, but you will need to change the injectors and convert to electric fuel. The 03 has split shot injectors so your computer won't run them properly. Also, the cam has no lobe for the fuel pump, so you've got to switch over to the electric fuel. Are you getting the intercooler and pipes too? If not, there may be a few more pieces you need to get or use the old ones off the 97.
Scroll down a little further till you find the OBS seciont (94.5 - 97 powerstroke). Those guys will be able to give you all the ins and outs of the swap.
Old May 11, 2012 | 09:03 PM
snakedoc's Avatar
snakedoc
the front cover is not the same
all the pumps are in a different place.
but if you have both motors then it should be a not problem.
Old May 11, 2012 | 09:23 PM
mueckster's Avatar
mueckster
The engine harnesses are different also. The OBS 7.3 uses 2 connector injector plugs on the VC gasket and UVCH while the Superduty has the single 9 pin connectors.
Old May 11, 2012 | 10:39 PM
CSIPSD's Avatar
CSIPSD
The motor will swap fine. You will just have to swap the accessory brackets.
Other then that and an electric fuel swap its a good long block for you. You can leave the injectors, they will run fine on the single shot tuning.
Old May 11, 2012 | 11:46 PM
Poolguy601's Avatar
Poolguy601
Have the complete vehicle. rear, side impact damage. Little front end damage. can drive it around farm.
A pause for the COZ
May 23, 2018 08:58 PM
never enough F-350s
Jan 23, 2017 08:30 PM
bennett11
Jan 24, 2013 11:34 PM
Biscayne
Nov 11, 2011 12:50 PM
usmchgb79
Feb 23, 2010 02:13 PM
