97 7.3 in a 2000 f250?
I posted earlier about an 03 7.3 fitting in my 2000 f250. Well turns out the engine is in fact a 97.
Can I make this work?
If I switch over the obvious things like,
Turbo, intake manifolds, injectors, UVC harness among other things.
Is it worth it as I have it at my shop and the price is right and only has 81 000k on it.
A little info on this would be helpful.
Thanks
Thanks
Yes, if you swap all the accessories and the injectors you will be good to go.
