Cruise o question
Old May 11, 2012 | 06:25 PM
musicmanbiker's Avatar
musicmanbiker
Cruise o question
My 65 with the com trans, has anyone removed the cooling box and run steel lines to the radiator? I think it might be cleaner than heater hoses going underneath the vehicle. Also saw a 3rd line on this trans that just hung in the wind any thoughts on that? Thanks guys, John
Old May 12, 2012 | 09:57 AM
napass2004's Avatar
napass2004
I have a 64 with the com my cooler rusted out from the water used to cool it so I did run it to the radiator and also added a trans cooler it works great and looks better also I don't understand why they decided to cool the trans with hot water good luck
Old May 12, 2012 | 12:19 PM
KO1960's Avatar
KO1960
My '65 looks to have had a radiator with an internal trans cooler, because the tube is flared with a nut behind the flare for the connection. Someone added a trans cooler to the front of the radiator and ran hoses from the steel lines. I'm not certain what the stock configuration should be. The tubing is just a loop for cooling the trans fluid, so the 3rd line may be a vacuum line from the intake manifold to the trans modulator, which is a steel line as well. Good luck.
Kurt
Old May 12, 2012 | 12:28 PM
napass2004's Avatar
napass2004
Mine also has a third metal tube that hags down like a vent it appears factory
Old May 12, 2012 | 06:33 PM
musicmanbiker
Thanks for the answers, it really does seem to be a vent of sorts. Will go with radiator for cooling. Thanks, John
SoCalAngler
Jan 13, 2018 12:52 PM
kbarbee95
20
Aug 2, 2015 01:39 PM
SoCalAngler
Aug 31, 2014 10:38 PM
Tecman
15
Dec 28, 2008 03:09 AM
skywagon
Mar 23, 2004 11:34 AM
