Radiator trans cooler lines
Does anyone know where I can get a kit and a write up on how to connect the transmission lines to the radiator?
Please and Thanks.
-Kenneth
The line from the front of the trans goes to the radiator, from the radiator to the air to oil cooler, the to the rear of the trans.
Part numbers are supplied assuming the new radiator is from Ford, and not an aftermarket radiator. There is no way to know what tank fittings an aftermarket supplier might provide. They could match, as that would make the most sense for selling the parts, but one never knows, so I begin with that caution.
If your radiator is a derivative of Ford Part #YC3Z 8005 BA, then the set of three lines that will make your transmission cooling system replicate the factory production fit of 2001 and later when Ford restored the oil to water cooler in production are as follows:
YC3Z-7A031-AA TUBE ASSEMBLY
YC3Z-7A031-CA TUBE ASSEMBLY
YC3Z-7R081-AA HOSE ASSEMBLY
And finally,
YC3Z-7N291-AA CLIP that retains the two hoses under the radiator support crossmember as they pass underneath on their way to the oil to air cooler in front of the radiator.
Don't worry if the part numbers have been superseded by later releases, designated by more recent prefixes, like 1C3Z or 2C3Z bla bla bla. But do indeed worry if the part numbers range with newer prefixes than the above, like 4C3Z or 5C3Z... as those are 1/2" lines that don't go to the radiator, but instead go to a filter block with push to connect fittings... completely different design... so don't go there.
Getting back to the list above, the 7A031-CA basic and suffix is the forward line coming out of the transmission, where the hot fluid from the torque converter is pushed out by the pump into the cooling circuit, headed straight to the in tank oil to water cooler. The advantage of buying this line is that it is all swedged connections at the flexible hose portion, on both ends. In other words, there are ZERO hose clamps in this factory line. It is a hard threaded connection at the transmission and at the radiator, and the flexible rubber vibration damping hose portion is swedged and sealed at both ends to the pre bent tubing. I get excited about this because I had a transmission line blow off at worm gear and spring clamp connections on other vehicles in the past.
I believe the 7R081-AA line is the cooled return line to the back half of the transmission, refilling the sump from the oil to air cooler.
I believe the third line 7A031-AA is the hard line output from the oil to water cooler heading up to supply the oil to air cooler.
I say "I believe" because I could have the part numbers to these two lines mixed, but I believe the foregoing is correct.
I ended up using the factory formed bends in my old removed hard lines to add an external transmission filter in such a way as to not cut any new factory swedged lines, and still secure the external filter against the frame, as opposed to hanging it's weight on the transmission line itself.
And finally,
I am just going with the trans to radiator line since I will be running a 6.0 cooler and the other line would not work for me.
