Radius Arm
Old May 12, 2012 | 06:28 AM
Godlover's Avatar
Godlover
Radius Arm
I am bolting the 79 suspension in my 65. I bought radius arm bushings for a 79 since this the new came from a 79. I can't get enough room to start the nut if I use the washer but I am close enough to start the nut with the washer. Any idea on how to squeeze it a bit tighter or should I have used bushings from a 65?
Old May 12, 2012 | 11:24 AM
66f-100's Avatar
66f-100
The bushings should be the same. I had the same problem when I did my disc brake conversion. Even with a helper, I couldn't get it started. I found it much easier to unbolt the radius arm from the I-beam. Then you can get the nut started easily. It will be easy for you to pull the i-beam back into position on the radius arm.
Old May 12, 2012 | 07:02 PM
Godlover's Avatar
Godlover
Got it! I used a c-clamp and pulled it back.
blk dog
Nov 22, 2010 06:09 PM
codyingersoll123
32
Feb 28, 2009 05:31 PM
kingford72
Jul 23, 2005 09:12 PM
BOYD FLY429
1978 - 1996 Big Bronco
Sep 2, 2004 04:29 PM
BigBrownTruck
Mar 14, 2001 12:13 AM
