Charging/Power Distribution Problem
Old May 10, 2012 | 10:51 AM
BudS's Avatar
BudS
'88 F150 SC,351,AT
My starter shorted out. Evidently something else blew out when that happened. Now I have power to the Dome light and the warning chime when key is in ignition when the door is opened. Turning key to start position does nothing but turn off the chime and dome light. There are no headlights at all. Fusible links on the starter relay wires are all good. Acts like there is another circuit breaker or fuse hidden somewhere. Only possibility I come up with is a bad ignition switch...ouch!
Any other ideas?
Old May 10, 2012 | 07:09 PM
rla2005's Avatar
rla2005
What year/model/engine/transmission truck do you have?
Old May 10, 2012 | 07:36 PM
BudS's Avatar
BudS
Truck yr,model,engine,trans
'88, F150,351,AT
Old May 19, 2012 | 09:14 PM
BudS's Avatar
BudS
When starter shorted out, the high current thru the battery ground wire overheated it causing the failure. Evidently there was enough of a ground connection thru other circuits to enable the domelight and chime to work but not enough to supply what was needed for big circuits. I cut off about 2 - 3 inches off the battery connecter ground wire to the frame and block, cleaned gunk off the terminal with wire brush, reconnected the ground wiring and everything now works. GOT MY TRUCK BACK!!!! OOH_RAH
Old May 20, 2012 | 09:18 AM
rla2005's Avatar
rla2005
Thanks for the feedback. Glad to hear you got the truck running again.
autochefc
1978 - 1996 Big Bronco
Oct 22, 2012 08:57 AM
greg in the oc
Sep 7, 2010 10:06 AM
shawngibbons
May 3, 2009 09:50 PM
wileec
Dec 29, 2006 01:50 PM
Agemenon
Nov 10, 2006 08:18 PM
