E40D replacement options
Old May 9, 2012 | 11:21 PM
77f100n00b's Avatar
77f100n00b
So I just bought a 95 F-150 Eddie Bauer. Power everything, automatic, v8. 150k miles. I've read a lot that the E40D tranny is horrible. What would be decent options to replace it with, or am I stuck with it? Thanks in advance for the info.
Old May 10, 2012 | 12:38 AM
Lead Head's Avatar
Lead Head
95 E4OD should be pretty solid. It will have quite a few fixes over the previous years.
Just keep the fluid changed in it.
Old May 10, 2012 | 04:12 AM
bucks150's Avatar
bucks150
I agree with Lead Head the e4od is a good tranny it had a lot of issues in the earlier models. I think ford got those fixed in 93. Keep the fluid changed and it will go a long time.
Old May 10, 2012 | 01:31 PM
GoinBoarding's Avatar
GoinBoarding
I was told that March 22 1995 and newer built trannies have a center support bearing in them. Once that was implemented they were super solid. I have 190k on mine, just change the fluid/filter and its working great. Either way, I wouldn't swap it out to anything else (quite a job to switch to manual, not as simple as you may think) unless yours is trashed.
Old May 10, 2012 | 07:28 PM
rangergirl94's Avatar
rangergirl94
I swapped to 5speed after my e4od let go at 198,000 and I do heavy towing
Old May 11, 2012 | 12:02 PM
hivoltj's Avatar
hivoltj
Why would you swap out a perfectly fine working trannie?
Anyway, late-'94 and on F5 trannies are much better. The front pump and center support problems were corrected, you shouldn't have much to worry about, just keep the fluid clean
Old May 12, 2012 | 01:38 AM
77f100n00b's Avatar
77f100n00b
thanks for the info everyone.
kdy72601
Mar 9, 2008 11:23 AM
Fishallot
1978 - 1996 Big Bronco
16
Oct 13, 2005 10:39 PM
LJ-mar
Jan 22, 2005 10:57 PM
Thom_James4991
May 15, 2003 09:39 PM
jbfire
Jun 4, 2001 09:14 PM
