E4od
Old Jan 22, 2005 | 09:21 PM
LJ-mar's Avatar
LJ-mar
E4od
94 F150 4.9L E4OD 190'000. Problem started summer of 2003. The
Transmission Works Fine without problems During The Cooler Months, Here
in Texas, But As Soon As The Tempture Gets to The 80's And Above The
Transmisson Occasionally Hard Shifts or Slams Between 2'nd And 3'rd. It
will Also Slip Out of Overdrive. Right now it is Working Without
Trouble. Any Clues?
Old Jan 22, 2005 | 09:43 PM
stepsider 94's Avatar
stepsider 94
Try changing the fluid including the torque converter replacing the filter and add a can of transmision fluid adative like slick fifty.It was recomended by a tranny shop and cured mine.
Old Jan 22, 2005 | 10:16 PM
ptt's Avatar
ptt
Additive......
Does anyone recommend Lucas transmission additive?
Old Jan 22, 2005 | 10:57 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Letting it go this long is a serious mistake. A slipping transmission is killing itself. You will be very lucky to fix it at this late date.
If you have not changed the fluid and filter yet it will be a miracle if you can fix it. You are supposed to change the fluid before it gets dirty. Changing it after you have problems like pulling your parachute in the treetops. There is a tech article here about changing your fluid, find it and read it. Break open your filter and look for broken parts.
Each transmission has a diagnostic routine that you have to run through to isolate problems. You need to find it and learn it even if you take your truck to a shop so that you will know if they are straight with you. Learn the tests and do the ones you can. If you can't fix it get someone to help with the tests you cannot do.
If you have to get another transmission make sure it has all of the updates.
Run some searches there is some good information here on the E4OD.
