Stop Light Switch
Old May 8, 2012 | 10:32 AM
cornking's Avatar
cornking
Stop Light Switch
I am having electrical problems with my trailer lights and brakes. I think it is a wiring problem, probably corrosion from the salt air I live in. In looking at my old installation instructions for the controller it mentioned incorrect wiring can kill this switch.
What is the stop light switch and where is it?
Old May 8, 2012 | 11:51 AM
hairyboxnoogle's Avatar
hairyboxnoogle
The stop light switch is the little button that mounts on the brake pedal, roughly 3 1/2" long, bout as big around as a nickle and usually black or grey, 2 wires come off of it. Costs about $2 at a parts store but without it, no trailer brakes or brake lights.
Old May 8, 2012 | 04:59 PM
cornking's Avatar
cornking
Thanks for the info, it is very much appreciated.
Old May 8, 2012 | 07:33 PM
tecgod13's Avatar
tecgod13
What are the problems you are having with the trailer lights? One of the biggest issues with trailer wiring is proper grounding. If there isn't a good ground at the truck that carries over to each of the lights on the trailer, weird things can happen.
Look over the connections everywhere and clean or replace anything thats corroded. I'm kinda in the same boat right now. The right tail light signal wasn't working at my trailer connector. I had built a junction box that fit in the bumper, but it leaked and a few things corroded. So I'm switching the setup to one mounted in the bed that I can get to and troubleshoot/fix a lot easier in the future.
I've also had the tail lights in my truck stop working because the ground for the lights failed.
Old May 9, 2012 | 04:05 PM
cornking's Avatar
cornking
I hate electrical problems. When one thing happens others start.
I have a cab-over camper on the truck and pulling a cargo trailer. I have no running lights, turn signals, flashers, or trailer brakes. I have a brake light on the left side. Camper and trailer. All the fuses check out.
I am 1500 miles south of the USA border. When I started my trip north everything was working. Two hours into the trip and everything started to slowly die.
I took it to an auto electrico mechanico today. In my best Spanglish I asked him to start at the front of the truck and work his way back checking all the connections. I gave him the schematic for the plug and the install instructions for the brake controller (in English). Now my finger are crossed hoping he understood.
In the past I have had good luck with Mexican mechanics. The cost is a lot cheaper too.
Old May 10, 2012 | 02:51 AM
Aune163rd's Avatar
Aune163rd
lol i love the comment about cheaper, In the United States, it seems....every kind of mechanic is 80 bucks an hour!!
Old May 10, 2012 | 11:00 AM
cornking's Avatar
cornking
Lalo, my mechanico electrico, just finished up fixing everything. Total cost including parts 1300 pesos or $100. That was for 9 hours labor. Got to love that.
I am going to be in shock when I get north of the border.
Old May 10, 2012 | 05:00 PM
tecgod13's Avatar
tecgod13
What was wrong? some bad connections, or something else broke? Just curious...
Thats definitely a lot cheaper than anyone you'll find north of the border.
Old May 10, 2012 | 06:25 PM
cornking's Avatar
cornking
I am not really sure everything he did. I know he changed the flasher relay and the 7-way connector on the truck. He also chased all the wires from the front of the truck to the back and cleaned up all the connections. I have a 7-way for the camper, a 7-way for the trailer, and an extension cord between the truck and the trailer ( my camper extends 4 feet beyond the rear of the truck). He also replaced all the bad bulbs.
I lost the clutch safety switch and the truck wouldn't start last night unless we jumped the solenoid. It was getting dark and he was getting frustrated so we jumped it and I took the rig home for the night. He came to my house this morning and tracked that down and now it is working.
No extra charge for the house call.
I hope to start my long trip to California on Saturday.
DonZ1029
Apr 9, 2017 01:06 PM
dmnj
All Things Towing
Mar 27, 2014 03:16 PM
texashottie
1978 - 1996 Big Bronco
Oct 2, 2004 11:11 AM
nomadic
20
Sep 15, 2004 07:47 PM
DAV1972
Dec 8, 2001 06:30 PM
