79 inline six timing help
Old May 7, 2012 | 05:51 PM
coleboy11's Avatar
coleboy11
79 F-100 300 inline six, engine has basic timing, but need to fine tune without timing light or electronics. Is it possible to rotate the distributor without getting electrocuted? Clockwise or counter-clockwise? Any advice here would be greatly appreciated, thanks
Old May 7, 2012 | 10:44 PM
mark a.'s Avatar
mark a.
I can't think of any reason moving a dizy would shock you.
Old May 8, 2012 | 12:50 AM
starwriter's Avatar
starwriter
I had to use a timing gun to get my i6 timed really well but this is what I would do.
1) Start engine
2) Unhook vacuum advance from distributor and plug vacuum line going to carb.
3) Loosen nut on base of distributor, I think it is 1/2 inch.
4) Rotate distributor until idle sounds right, about 800 RPM. Exhaust shouldn't burn your nose.
5) Tighten nut on base of distributor.
6) Attach vacuum advance and rev engine checking for stumble, if all sounds good take her for a drive and see how she runs. I usually end up pulling over and adjusting slightly while driving.
Hope this helps.
Old May 8, 2012 | 08:52 AM
coleboy11's Avatar
coleboy11
Well I've been tuning it by ear several hours now and its driveable, but I cant seem to get that little stumble out no matter what I do, so I hit the neighbor up for a tutorial and a timing light. He should be here by 4 PM, but the degrees is 10 right for a 79?
Old May 8, 2012 | 10:01 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Make sure your vac advance is functioning and that the accelerator pump is squirting fuel out the discharge nozzles.
Old May 8, 2012 | 10:02 AM
nlareau's Avatar
nlareau
Chances are the stumble isn't due to timing. My has it at low RPMs and I think it is more a function of the accelerator pump in the carb.
Old May 8, 2012 | 10:23 AM
starwriter's Avatar
starwriter
10 degrees was about right for my truck. Mine stumbled for a long time it was a conbination of timing, carb and fuel pump. I had to go through about 2 carbs before I found a good one and I still had to tune it. I won't ever git rid of the carb I have now just keep rebuilding it. If you are running the stock carb it isn't hard to tune, just 1 screw. Tighten it down until the truck starts to stall out then back it out a turn or so. Keep backing it out until the exhaust doesnt' burn your nose. It took me awhile to get the hang of it but it's an easy enough engine to learn on. After figuring this all out I now get about 17mpg and no stumble so I figure I must have it tuned about right. It took me a few tries to get it right though.
Old May 8, 2012 | 11:31 AM
Goofy1129's Avatar
Goofy1129
the timing
was doing some reading in the Chilton's or Hanyes book for my 76 F100 with the 300 inline and it stated that the timing was supposed to be at 12 degrees before top dead center hope that helps.
Fetruck86
May 29, 2016 08:42 AM
ftrk66
Dec 11, 2012 11:53 AM
SideWinder4.9l
Mar 11, 2011 02:58 PM
adams.construction
13
May 9, 2010 01:09 PM
wantaford
Jun 11, 2007 01:55 PM
