delete
Old May 7, 2012 | 05:31 PM
Deslfrk24's Avatar
Deslfrk24
delete
hey everyone i have an 84 f-150 with the 300 i6 and 3 speed transmission on the column. my "colomn collar" snapped off. how should i proceed to try and replace it. i figure you have to pull the wheel off but after that i cant figure out how to remove lock cylinder or anything else. is this something i should take to the dealer or what? i do have some mechanical training but never had to deal woth anything like this on an older truck like this.
Thank you for any input or assistance.
Old May 7, 2012 | 08:04 PM
82f100460's Avatar
82f100460
If you're going to be disassembling several things (steering wheel, key lock cylinder, turn signal switch, etc....) I would recommend getting a simply Haynes or Chilton Manual. It walks you though all of this and then you'll have it for future use as well.
to remove the key lock.....take it to run and insert a drill bit (or something small) into the hole by the cylinder...it should come out at that point.
fordtrck302
17
Dec 6, 2015 05:21 PM
Warspring
Dec 24, 2013 12:33 PM
sixshootingexp
Dec 31, 2009 08:55 PM
99Ranger43k
1983 - 2012 Ranger & B-Series
Oct 11, 2008 12:17 PM
KamloopsHunter
Feb 10, 2006 02:38 PM
