Key Lock Cylinder?
Old Dec 31, 2009 | 12:10 PM
sixshootingexp's Avatar
sixshootingexp
Key Lock Cylinder?
I have a 95 f-150. It wont turn off. I can take the key out, and it is still running.
I am wondering if I need to take the steering wheel off?
Also, what about the airbag?
I also read in some posts with same problem that it might be the "acuator rod"?
My haynes dont say anything bout the airbag, or an acuator.
Help?
Old Dec 31, 2009 | 12:51 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The electrical switch is farther down the column, the actuator rod connects it to the key switch.
If the rod breaks it may be able to push the switch on but will not retract to the off position.
Old Dec 31, 2009 | 12:54 PM
Hitokori's Avatar
Hitokori
the lock cylinder is prolly broke... the actuator rod runs down the column to the switch unit.... the air bag doesnt really matter other than u have some screws in the back of the steering wheel that u have to undo then pull it off....
um im really not sure how to remove the lock cylinder but some one else here is bout to have done it with ur model truck.... mine is an 88 and has a different column
srry cant be any more help
Old Dec 31, 2009 | 01:04 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
This post may help...
There is a thumbnail so you can see the components at the top of the column.
Originally Posted by BChance
REMOVAL & INSTALLATION
With Key
1. Disconnect the battery ground.
2. On tilt columns, remove the upper extension shroud by unsnapping the shroud from the retaining clip at the 9 o'clock position.
3. Remove the trim shroud halves.
4. Unplug the wire connector at the key warning switch.
5. Place the shift lever in PARK and turn the key to ON .
6. Place a 1 / 8 in. (3mm) wire pin in the hole in the casting surrounding the lock cylinder and depress the retaining pin while pulling out on the cylinder.
7. When installing the cylinder, turn the lock cylinder to the RUN position and depress the retaining pin, then insert the lock cylinder into its housing in the flange casting. Assure that the cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This will allow the cylinder retaining pin to extend into the cylinder cast housing hole.
8. The remainder of installation is the reverse of removal.
Non-Functioning Cylinder or No Key Available
FIXED COLUMNS
2. Remove the steering wheel.
3. Remove the turn signal lever.
4. Remove the column trim shrouds.
5. Unbolt the steering column and lower it carefully.
6. Remove the ignition switch and warning buzzer and pin the switch in the LOCK position.
7. Remove the turn signal switch.
8. Remove the snapring and T-bolt nuts that retain the flange casting to the column outer tube.
9. Remove the flange casting, upper shaft bearing, lock cylinder, ignition switch actuator and the actuator rod by pulling the entire assembly over the end of the steering column shaft.
10. Remove the lock actuator insert, the T-bolts and the automatic transmission indicator insert, or, with manual transmissions, the key release lever.
11. Upon reassembly, the following parts must be replaced with new parts:
Flange
Lock cylinder assembly
Steering column lock gear
Steering column lock bearing
Steering column upper bearing retainer
Lock actuator assembly
12. Assembly is a reversal of the disassembly procedure. It is best to install a new upper bearing. Check that the truck starts only in PARK and NEUTRAL.
Old Dec 31, 2009 | 01:14 PM
sixshootingexp
Thanks
I cant really see anything on the thumbnail, but at least I am gaining confidence...
I am goin to pull the shrouds off and have a look.
Old Dec 31, 2009 | 01:32 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Here is a link to the thread I got it from: https://www.ford-trucks.com/forums/8...ition-fun.html
Evidently the forum software won't let me cut and paste the quoted post..
Old Dec 31, 2009 | 05:11 PM
sixshootingexp
not the problem
Just put new cylinder in, and it is doing the same thing.
I seen some other posts about it being the actuator rod, but orielly never heard of that.
The manual doesnt show how to replace it, and, now im getting worried.
Old Dec 31, 2009 | 05:21 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The rod is pictured running along the top of the column in the thread I linked to.
It is pot metal and can break, especially if you have a tilt column.
I'm not there to diagnose your truck, but just suggesting that it may be the problem.
YMMV
Try using the advanced search function. "ignition actuator rod" in the '87-'96 forum only.
You will find all the threads illustrating this.
Old Dec 31, 2009 | 08:55 PM
sixshootingexp
thank u
I am very frustrated because I lack the knowledge and a good place to work on stuff. I appreciate your help..
I will do as you say, and research the posts.
Thanks again
m@m
2004 - 2008 F150
17
Feb 12, 2015 09:11 AM
Forger
Aug 2, 2012 01:11 AM
sthrnforddriver
Sep 21, 2010 10:42 AM
sean23johnson
17
Feb 6, 2007 08:05 PM
KillerQueen
Jul 30, 2006 12:27 PM
