engine swap
Old May 6, 2012 | 08:38 PM
topfuel's Avatar
topfuel
engine swap
I have a 66 f100 3 on the tree with 300 six with a rod hanging out of the side of the block. I got a deal on a 78 f100 with a nice 302 and a c 4 behind it. I just want to drop in the 302 and keep the 3 speed, will this work? Was told I will need another flywheel. Also I would like to keep the electronic dist on the 302. How do I do this?
Old May 6, 2012 | 08:50 PM
jacks61ford's Avatar
jacks61ford
the dizzy is easy enough to wire up the 302 should bolt straight to the trans but yes you will need a new flywheel
Old May 6, 2012 | 09:01 PM
garbz2's Avatar
garbz2
You will need small block specific perches and truck insulators.
Garbz
Old May 6, 2012 | 09:08 PM
topfuel's Avatar
topfuel
parts truck
I can rob the parts truck for the motor mounts and perches right? The 78 also has new headers and flow masters on it. I was hoping this would swap over as well...............
Old May 6, 2012 | 09:28 PM
garbz2's Avatar
garbz2
Everything from the 78 donor will swap over. Do a disc brake conversion while you have the parts truck.
Garbz
Old May 6, 2012 | 09:41 PM
topfuel's Avatar
topfuel
Brakes
I would like to swap out the single master cyl for the double also. besides the booster and master cyl, I need a proportioning valve in there right? do I need the i beams of the newer truck to do the disc swap? How many Beers will I need?
Old May 6, 2012 | 09:49 PM
topfuel's Avatar
topfuel
rearend
What is the rearend in the 78? did they make an 8.8 back then? I dont want to junk it with that rear when Iam done if it is . keepin the 9in the 66.....
Old May 6, 2012 | 10:00 PM
Bill W's Avatar
Bill W
it will be a 9 inch in the 78
Old May 6, 2012 | 10:06 PM
C G B's Avatar
C G B
Wouldnt the 78 read end be too wide though? I think the last year for same sized rears is 73 if I recall correctly.
Old May 6, 2012 | 10:10 PM
topfuel's Avatar
topfuel
rear
all I know is the 78 does not have a 9 in it. It has a rear cover, I dont know what it is.
Old May 6, 2012 | 10:17 PM
topfuel's Avatar
topfuel
it runs
Can you believe the 300 still runs with a rod flopping around and a hole in the block! I bet if I dropped the pan and pulled out the busted giblets and jb welded the hole it would be fine for another 100,000
Old May 6, 2012 | 10:18 PM
C G B's Avatar
C G B
Most likely a Dana 44 then. Not a horrible rear, as they have some advantages over a 9", mainly they are slightly more efficient. However the 9 is definitely tougher.
Should be some casting marks ont he case somewhere. Just Google "dana 44 identification" and that should get ya going the right direction.
Old May 7, 2012 | 11:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No 8.8's until 1983.
Some 1977/79 F100/150's came with Dana 44-3 rear axles with or without Limited Slip.
The AXLE code is stamped on the Warranty Plate. If it begins w/a letter: Limited Slip. If w/a number, no Limited Slip.
37 1/2" width between the inner frame rails behind the cab: All 1973/79 F100/350's except as noted below.
33 1/2" width between the inner frame rails behind the cab: 1961/72 F100/350 / 1973/77 F250 4WD (High Boys) / 1973/79 F350's on the 140" wheelbase.
Old May 7, 2012 | 11:55 AM
C G B's Avatar
C G B
Thanks for the reminder Bill. I couldnt remember if it was 72 or 73 and didnt feel like looking it up...
wglore
Jul 9, 2015 05:24 AM
Undertheoaks
Mar 30, 2014 09:48 PM
jokere
Sep 25, 2010 10:34 AM
paden
Engine Swaps
Feb 12, 2007 06:58 PM
