78 302 engine swap
Old Mar 29, 2014 | 07:06 PM
Undertheoaks's Avatar
Undertheoaks
78 302 engine swap
Curious minds need to know. I have a 78 f100 with stock 302 4-speed and curious if a 302 out of a 78 Bronco would fit and replace mine ? It has everything except Exhaust manifolds and flywheel and I want to swap my parts onto it. Broncos 302 engine # is D10E5015AA
Old Mar 29, 2014 | 08:05 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Any 302 short/long block will swap for another, no worries.
Old Mar 30, 2014 | 02:57 PM
Conanski's Avatar
Conanski
And in this case these two motors are identical.
Old Mar 30, 2014 | 09:48 PM
baddad457's Avatar
baddad457
Well that Bronco's 302 isn't a 78 motor but more'n likely a reman or rebuild built around a 71-up vintage block. Before you toss your 78 block, look at the casting numbers first. If it's a D8VE-6015-A3A, then you've got an excellent stroker candidate. Or even if it's the 3A suffix, it's still a good-un, the same casting as that D1 block. The A3A has the bigger Hi-po/Mex main caps.
topfuel
13
May 7, 2012 11:55 AM
auggieinks
Oct 22, 2009 09:35 PM
redgie
Feb 21, 2008 07:23 AM
DJAbby
1978 - 1996 Big Bronco
Jun 15, 2003 01:50 PM
