Hard to tell from the photo; however, I do not see a vent for the fuel. That 2” outlet is designed to mount a regular pump to transfer fuel into other vehicles. You might be able to rig it so that it would work. It looks rather “homemade” and who knows if the tank is baffled or not. Again, it’s your money but saving a few bucks here may end up costing you more in the end. The other issue is the height of the box. Is it going to ride above the rail and if so are you ok with that.
I have a 37 like the one from tractor supply.Have had it for 8 years.Took neck off my tank and brazed on a fitting and drilled hole in bottom of new tank and did same thing.Drilled hole in truck bed and added a gromet and ran a fuel line.It is gravity flow and never had a problem.
Originally Posted by danskool
Thanks, That is what i am thinking of doing. I haven't decided yet, just checking craiglist everyday as i have been doing for almost a year now.
I've been saying this and doing this for over a million miles without any issues.
