Trouble with inline transmission filter
Old May 9, 2012 | 06:34 PM
A H DEVELOPMENT's Avatar
A H DEVELOPMENT
Question Trouble with inline transmission filter
2001 F350 7.3L 4R100 My inlne transmission filter has always leaked, transmission and filter replacements @ 30K -40K mile intervals. I have tried multiple brands with same result. My reman transmission has atleast 120K miles, mostly light duty. The last time I asked the dealership tech about it he said they are now just taking them off because they are no longer needed because due changes in the transmission servicing, however I would like to keep mine as a safeguard. Both the tech and I agreed that there appears to be a filter failure that allowed fluid through the plastic body. Seems like a pressure problem to me? I have searched and searched to find another magnetic filter that is more heavy duty and maybe with a metal housing. Do not have the money to do a bypass style upgrage with a large capacity filter, like @ BD.
Old May 9, 2012 | 06:51 PM
danskool's Avatar
danskool
Go Bills !
This summer, I will be adding a filter.
This type leak on you? This is what i was going to do.
Magnefine 3/8" Inline Magnetic Transmission Filter | eBay
You good do the springerpop mod SpringerPop's Transmission Filter
Old May 9, 2012 | 06:54 PM
smithrock's Avatar
smithrock
I threw a Magnefine on mine. Tranny doesn't seem to mind it!
Old May 9, 2012 | 07:35 PM
nlemerise's Avatar
nlemerise
Just put a screw-on transmission filter and throw a couple of rare earth magnets on the canister.
Old May 9, 2012 | 08:44 PM
Ponyboychris's Avatar
Ponyboychris
These are good filters. Not very expensive either.
If you don't want to do the ebay route, you can get them here: Vandal Alert Automotive Products-Supplier of Products to the Automotive Dealer, Fleet and DIY Market.
Old May 9, 2012 | 09:07 PM
smithrock's Avatar
smithrock
Got mine off Amazon
Old May 9, 2012 | 10:12 PM
A H DEVELOPMENT
No one else has had this problem????????
Old May 9, 2012 | 10:20 PM
A H DEVELOPMENT
Maybe, but I am concerned because I do not do my own transmission service, and I am sure the tech will have something to say about it and blame any issues on it. For that very reason I am forced to keep my truck running STRONG but STOCK(mostly).
I was hoping to find a direct heavy duty replacement.
Keep posting guys, Thanks!
Old May 10, 2012 | 06:17 AM
danskool's Avatar
danskool
Go Bills !
Is the magnefine filters that are leaking on you?
Old May 10, 2012 | 08:31 PM
A H DEVELOPMENT
Yes it appears to be the actual body/housing that fails and weeps transmission fluid. I can only think that it can not handle the line pressure. Does not matter what weather temperature or if I am towing or not?
Thanks for the reply
danskool
Old May 10, 2012 | 09:36 PM
Ponyboychris
My previous truck (late 99) had several Magnafine filters on it when I had it and I never had an issue with leaks and that was towing a fifth wheel all over the Rockies. I'm very sure I put it through some tough trials and it worked without a hitch. I cannot see them failing because of pressures but something must be going on for you to have issues with them. Maybe Mark K can chime in with some more insight.
Old May 11, 2012 | 11:46 AM
A H DEVELOPMENT
Thanks for the post ponyboychris.
vancouver f250
Aug 16, 2013 10:45 AM
whporwil
6.4L Power Stroke Diesel
Aug 12, 2010 06:46 AM
