Sponsored by: Kumho
steering wheel hiss
Old May 5, 2012 | 08:55 AM
kbsupercrew's Avatar
kbsupercrew
steering wheel hiss
Does anyone have a fix for the faint hiss noise,(fluid transfer noise that travels up the steer column) that is only heard in the cabin , sounds like a shhhh noise that is very faint when you turn the steering wheel slightly left or right and sounds like it is right behind the horn cover?
2000 f150 5.4
some research says this is normal?
Changed the pump, high pressure, return, cleaned res, fluid change (merc v)
Seems to be only present after driving for a while( hot fluid)
Steering gear valve fluid noise excessive?
New ball joints upper and lower recently, but Ive had this noise for years trying now to tackle it
No noise with front end up in the air turning engine on or off
rangerottis
2004 - 2008 F150
Dec 19, 2015 07:20 PM
kbsupercrew
1997 - 2003 F150
May 6, 2012 01:59 PM
johnw
Mar 4, 2007 07:39 PM
96explr
Mar 10, 2006 08:07 AM
EgoMan
Aug 11, 2004 10:24 AM
