Driveshaft Length and replacement
Old Aug 13, 2022 | 11:52 AM
FuzzFace2's Avatar
FuzzFace2
It may as I dont know on the AOD & C4 yoke
Try this link as I am sure that is where post 3 got it from
https://www.garysgaragemahal.com/drive-shafts.html
I cant believe there is no one in Nashville that dose car / truck drive shafts.
The one I used here just outside Raleigh MC (Gardner NC) dose big rig truck shafts but was able to make mine for my 81 F100 flare side with NP435
Why I needed one made I have Advance Adapter Range Splitter over drive between motor & trans making the drive shaft shorter by 7.5 inches.
Check out large truck shops if they can help on the shaft.
Dave ----
Old Aug 13, 2022 | 06:42 PM
Franklin2's Avatar
Franklin2
Originally Posted by 150R
I thought the AOD/4R70W was the same yoke as a C4. And thats why I would like the drive shaft chart. The two places in Nashville only make tractor drive shafts, no balancing, and Im afraid that in shipping one will get destroyed
Not sure what your plans were on getting a driveshaft. Most are bent at the junkyard when they pick them up with a forklift. I see Copart picks them up with a big loader from the front or rear for that reason.
Old Aug 14, 2022 | 07:04 AM
FuzzFace2's Avatar
FuzzFace2
Along that same line the DS I took to the shop to have it shorten had a little dent I fond when cleaning it before I took it.
Shop seen the dent and said cant use that tube and had to be replaced.
The dent was in the center and I knew he was right as the tube could be bent.
Dave ----
cannonman
Aug 22, 2016 03:40 PM
80s Trucker
Jan 17, 2011 09:07 PM
ejhodges2002
Jul 9, 2007 11:25 PM
SPRPRBGT
Dec 28, 2006 02:03 PM
duece-bigalo01
May 9, 2004 03:05 PM
