Greetings all. I've got a 1978 F100 swb 2wd with the glorious 300. She used to have a C6 auto trans but now has a C4 auto. As you might have surmised, my stock driveshaft is now aproxamatley 3 inches shorter than needed. Trying to find another Ford driveshaft but am open to other potions. The old shaft is 53 3/4 inches. How tricky should this be?
Why not have a new shaft made at a shop? Find a driveline shop and they can make you up a new driveshaft whatever length you need. Otherwise you are just stuck going through endless junk yard driveshafts with a tape measure trying to find one that will work.
Hi Cannonman, you'd probably get a lot more help in the forum for your year truck, instead of the engine (since it's non-engine related), so I'm going to move your post.
Hey Cannonman I just went through the driveshaft issue myself. Finding one will be a hit or miss thing if you go to the junkyard and start measuring. There are three options really;
1) Take your short driveshaft to the local drive line shop with you measurements and have yours extended (most likely under $200).
2) Take your measurements to your local drive line shop and have a new one made (most likely $300 +).
3) Buy a shaft of the same diameter at the junkyard that is longer than you need and build your own. I was able to do this for the front shaft in my 4x4 since I didn't want to shell out $300 plus when I have a lot of other things to buy.
The third option is only doable if you have a welder and some tools to ensure that the run-out of the shaft is as close to zero as you can get.
