From the manual. Can't say I would swear by it. I'll try to verify later on.
CASTER
Minimum +2.0°
Maximum +6.0°
Split -0.5°±+0.4°(-0.9°to -0.1°)
CAMBER
LH +0.25°±+0.5°(+0.20°to +0.30°)
RH +0.25°±+0.5°(+0.20°to +0.30°)
Split 0.0°±+0.4°(-0.4°to +0.4°)
TOE
Total +0.06°±+0.25°(-0.19°to +0.31°)
DOGTRACKING
Centerline of Front Tires Compared
to Rear Tires 30 mm (1-1/4 Inch) maximum
LEAN (SIDE-TO-SIDE HEIGHT DIFFERENCES [MAX])
Front Wheel House Opening 15 mm (5/8 inch)
Rear Wheel House Opening 20 mm (3/4 inch)
Rear End of Pickup Box 20 mm (3/4 inch)
