Machining Wheels
Old May 3, 2012 | 11:59 PM
4x484150's Avatar
4x484150
Machining Wheels
I have a set of aluminum wheels for my truck, and they need flat lugnuts, not like factory tapered nuts. I'm having difficulty locating these nuts, as the wheels are from the late 70's/early 80's.
Would I be able to take them to a machine shop and have them tapered like a stock wheel? I wanted to ask here before I bothered a shop with a stupid question. Thanks all!
(I'll post a pic of the lugnut holes tomorrow.)
Old May 4, 2012 | 01:13 AM
kedwinh's Avatar
kedwinh
Are they the centering type bolts they uses on older aluminum wheel? The kind where part of the bolt goes into the hole to center it? Might try a tire shop or even a junkyard.
Old May 4, 2012 | 09:25 AM
82F100SWB's Avatar
82F100SWB
Summit racing and the likes all carry the lug nuts for mags. Have a look here: http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
Old May 4, 2012 | 09:32 PM
4x484150's Avatar
4x484150
Kedwinh: I think you're right.
82: Thanks for the link.
Here are a few pics:
Old May 4, 2012 | 09:38 PM
first today's Avatar
first today
You need the shanked lug nuts for those wheels.
Old May 4, 2012 | 10:34 PM
4x484150's Avatar
4x484150
Thanks first today. So what's the F150 length and thread size of the studs?
Old May 4, 2012 | 11:41 PM
fellro86's Avatar
fellro86
The thread is 1/2, length is determined by the depth of the wheel. I know Autozone carries them with the washers, but for full sets you are likely better to get them from Summit or such places.
Old May 5, 2012 | 09:14 AM
Gary Lewis's Avatar
Gary Lewis
I think you'll be better off using the shanked nuts than having the wheels machined. I'd bet it'll cost a lot less and there's no chance that a mistake will be made during the machining.
But whichever way you go I would suggest using anti-seize compound where the nut and/or washer meets the aluminum. Otherwise it is highly likely that the aluminum will adhere to the steel and a degradation will begin on the mating surface. I've found this on our late model vehicles so I cleaned the nuts and started using anti-seize and the problem hasn't returned.
Old May 6, 2012 | 02:50 PM
4x484150's Avatar
4x484150
Thanks fellro and Gary! Great info on the anti-seize.
old58
61
Aug 18, 2015 03:37 AM
whitedogintheback
20
Apr 3, 2014 09:33 AM
joshcwa
15
Aug 26, 2012 12:23 AM
A/Ox4
Jan 14, 2012 09:37 PM
sampsin
Feb 22, 2005 01:11 PM
