Turbo Question
Old May 3, 2012 | 09:46 PM
Roasted7's Avatar
Roasted7
Turbo Question
How can you tell the difference between stuck vanes or a bad solenoid?
I'm having some turbo issues. My VGT duty cycle is all over the map and my boost is sometimes low but not always.
Old May 4, 2012 | 10:16 PM
Roasted7's Avatar
Roasted7
It it true that over diluted oil will ruin your VGT control valve?
Old May 4, 2012 | 10:51 PM
BLADE35's Avatar
BLADE35
IMO deluted oil would Wreak more Havic on other things Main Bearings,lifters,turbo float bearings,injectors ect.. than it would on the VGT valve. But still could be hard on the VGT Valve
the VGT valve just controls oil flow to the piston on one side or the other to control Varible Veins in the turbo
Do you have Diesel Fuel in your Oil???
Old May 4, 2012 | 11:04 PM
Roasted7's Avatar
Roasted7
I don't know yet. I kind of suspect though. I'm sending a sample in for analysis from my next oil change.
I thought I had read that in the turbo tech guide but it was in reference to the bearings.
"Note: For 6.0L Powerstroke diesel engines with engine oil diluted with four or more quarts
of fuel, the turbocharger endplay needs to be checked (.001” - .004” allowable). Also
check radial shaft movement by lifting the shaft up and rotating the shaft to check for
compressor or turbine wheel to housing contact. If any wheel contact is noticed, the
turbocharger must be replaced."
whalebus2112
Dec 2, 2012 08:25 PM
aaronlaaron
Apr 28, 2009 10:33 AM
why165
Nov 23, 2006 01:35 AM
DD1684
20
Mar 15, 2006 01:06 AM
chris128
Nov 25, 2005 05:33 AM
