Steering
Old May 3, 2012 | 01:55 PM
swampfire79's Avatar
swampfire79
Steering
03 King ranch Fx4
Steering got real easy all of a sudden and it won't return to center while driving. It seems as its too easy to turn. While driving down the road if u turn either direction and let go of the wheel it continues in that direction. It does not pull to either side while driving straight. Any suggestions?
Old May 4, 2012 | 08:35 PM
dlibson's Avatar
dlibson
Originally Posted by swampfire79
03 King ranch Fx4
Need to check the axle shaft u-joints, steering box, and ball joints.
Old May 5, 2012 | 07:40 AM
Rusty Axlerod's Avatar
Rusty Axlerod
I haven't had a problem with mine but here's a thread with the same issue and a LOT of posts. Might have some good insight if you haven't seen it already:
https://www.ford-trucks.com/forums/1...to-center.html
Here's a good thread on p/s flush and filter install:
https://www.ford-trucks.com/forums/8...ml#post7197232
Old May 5, 2012 | 12:11 PM
swampfire79
Thanks ill try it.
Old May 8, 2012 | 07:28 AM
04Muscle350's Avatar
04Muscle350
Axle ujoints
Old May 8, 2012 | 07:35 AM
swampfire79
Every thing under the front seems to be good. Its not hanging up or sticking. Its just very easy to turn and has no back pressure. Its hard to explain. Easiest way to tell you is drive your truck and turn left or right then turn loose your steering wheel. It will automaticly return to center. Mine doesn't return.
Old May 8, 2012 | 08:17 AM
04Muscle350
Mine was doing the exact same thing. Got real bad to the point it was dangerous cause it wouldn't really return to center. And when it finally returned to center you were almost in the ditch. Swapped out front axle ujoints and all better. Have you had them checked?
Old May 8, 2012 | 09:24 PM
dlibson's Avatar
dlibson
It's not easy to check the u-joints in the truck. Gotta pull the shafts.
2002exPSD
Feb 23, 2012 12:57 PM
Bob Gervais
Sep 17, 2010 05:40 AM
indyF-350psd
Jun 15, 2009 10:29 PM
bonecarver
May 3, 2007 04:10 PM
Its no M3A3
Dec 27, 2006 08:24 PM
