Throttle Issues
Old May 3, 2012 | 09:49 AM
so2315's Avatar
so2315
Throttle Issues
I have a 2002 7.3L and have noticed some issues with the throttle. It is hard to explain, but it feels like there is a spot on the pedal that is dead. When accelerating it is fine, but if I was to hold at 45 mph, and you are feathering the pedal with your foot to maintain this there is an area in the travel that the engine has no response to.
I now the day's of cables are long gone, so I was wondering if there is some type of switch under there that transmits the data? The only other thing I am wondering is if it would be the CPS acting up, but from what I've read those usually make the truck DOA.
Old May 3, 2012 | 09:57 AM
woodnthings's Avatar
woodnthings
Your throttle pedal has a potentiometer in it. It could have a dead spot, not uncommon to see that.
Throttle Pedal AE Video - YouTube
Old May 3, 2012 | 09:20 PM
PwerStroke99's Avatar
PwerStroke99
Agreed with Ken, TPS is going out
Old May 4, 2012 | 06:30 AM
Tugly's Avatar
Tugly
Dirty TPS. Look at the top of your pedal and you'll see the TPS. You might be able to clean it by spraying contact cleaner on it (Radio Shack or other electronics store will have it). One way to be sure is to get to that speed and set your cruise - then hold the accel button to see if it's smooth.
guitarpicr
Feb 26, 2017 08:02 AM
Peterbilt376x
Dec 3, 2014 07:10 PM
Chris611
6.7L Power Stroke Diesel
Apr 4, 2014 09:37 AM
joeyd61
Mar 5, 2013 02:18 PM
Idiomaticman
Jun 17, 2012 10:36 AM
