Transfer case output nut
Old May 2, 2012 | 09:58 PM
goldswim5's Avatar
goldswim5
So I've been hearing some clunking lately, and noticed my rear driveshaft had some play in it. Tonight I took it off, and the nut on the tcase was finger tight, I spun it off by hand. So my question is simple, what is the torque spec on that nut? I've searched and can't find it anywhere. And when I put it back on, can I use some blue threadlocker so this doesn't happen again? Thanks!
Old May 2, 2012 | 10:05 PM
joeyd61's Avatar
joeyd61
If I remember correctly it's 150 ft lbs...I cant see why the thread locker would matter..
Old May 2, 2012 | 11:32 PM
goldswim5's Avatar
goldswim5
I can't either, but you never know. Thanks man.
Old May 3, 2012 | 08:06 AM
mueckster's Avatar
mueckster
The correct torque for output shaft nut is 186 ft-lbs. The 12 pt flange bolts are 75 ft-lbs.
Old May 3, 2012 | 10:02 AM
Fat Diesel's Avatar
Fat Diesel
Mine would "chirp" when the nut got a little loose. Nothing finger tight though. I used some red threadlocker on it.
Old May 3, 2012 | 10:59 PM
crop harvester's Avatar
crop harvester
I would use nothing less than red permanant strength loktite. 271 is great.hopefully the splines didnt get damaged to much or you will be tightening that nut often.
MRStace84
Jul 28, 2010 05:05 PM
MineralStang
Oct 25, 2007 10:49 PM
bloomy63
Jul 26, 2006 09:09 AM
sbishop
Mar 8, 2004 06:14 PM
