Transmission??
Old May 2, 2012 | 09:27 PM
70truck's Avatar
70truck
Transmission??
I have an '88 F-150 4x4 with a 302. How do I know which trans I have? I don't think it has overdrive. It doesn't have the yellow dash button for OD and even with 35s I still turn around 3k rpm going down the highway. I would like to swap in a trans with overdrive. What trans would I need and what all would I need? Would I have to change the computor? Thanks!!
Old May 2, 2012 | 09:37 PM
GNR22's Avatar
GNR22
On your door jamb there will be a trans code along with your rear end code and everything. If you want an OD trans there are a couple options, but would you want to keep an automatic or swap to a manual?
Old May 2, 2012 | 10:12 PM
ctubutis's Avatar
ctubutis
Old May 3, 2012 | 12:10 AM
70truck's Avatar
70truck
Thanks yall! I would want to keep it an automatic.
Old May 3, 2012 | 02:23 AM
70truck's Avatar
70truck
Ok, the door tag says "K" and I counted 17 bolts, so I guess that means C6. What automatic trans with overdrive could I swap in place of the c6 and mate to my transfer case?
Old May 3, 2012 | 07:48 AM
Lazy K's Avatar
Lazy K
An AOD would probably be the best bet as, like your C6, no computer is needed to run it.
However give it a lot of thought as the C6 is tough.
Old May 5, 2012 | 11:10 AM
70truck's Avatar
70truck
Ok, so an AOD would be a bolt swap? What year truck would I find one in? What would be the door code for an AOD?
Old May 6, 2012 | 03:03 PM
70truck's Avatar
70truck
Old May 6, 2012 | 05:05 PM
ctubutis's Avatar
ctubutis
It'd be more involved than a bolt-on swap, probably would involve moving the tranny mount cross member forward or back,then there is the mechanical linkage from the throttle cable down to the transmission.
It is exceedingly important that linkage be installed & adjusted properly to avoid burning up an AOD.
1988 F150 with a 302 is going to be computer-controlled EFI. I think I've read out here somewhere on FTE about people hooking up an AOD to such a setup (to my knowledge, Ford would have given you a computer-controlled E40D and not an AOD which was used on non-computer-controlled drivetrains, generally with carbs) and I remember it involving aftermarket accessories, possibly a Lokar cable or something like that. It will take some custom fabrication and you need to do your homework first.
The FoMoCo 1980/89 Light Truck Parts Catalog lists several door codes for automatic overdrive transmissions.
Amongst them:
Code T, used 1981/1989 (and possibly longer but I have no way to verify that)
Is either the F10D, AOD, T50D, A4LD
Code Y, used 1985/89 (and possibly longer, as above)
Described as a 4-speed Automatic (O/D)
Code 7, used in 1985
Old May 6, 2012 | 07:44 PM
pfogle's Avatar
pfogle
In '88 behind a 302 it would have been an AOD or a C6. If your truck is equipped with a towing package you'd have a C6 (P R N D 2 1). If you didn't have the towing package it was an AOD (P R N OD D 1).
Old May 8, 2012 | 05:32 PM
70truck's Avatar
70truck
It has a hitch on it but I don't know if it is factory. I have the c6 (P R N D 2 1). Is there an automatic trans that would be a bolt in swap. Not really wanting to have to modify a lot.
Old May 8, 2012 | 08:30 PM
pfogle's Avatar
pfogle
The AOD will swap in, but you'll need the TV (throttle valve) cable and bracket. Then you'll need to adjust it for proper pressure in the trans.
Old May 10, 2012 | 11:55 AM
70truck's Avatar
70truck
Do they sell those aftermarket, or will I have to use one off a donor truck? How do you know what the proper pressure is?
Anybody know what year/code the AOD i'll need is? I assume I can use a truck or bronco trans right? Will my transfer case bolt to the AOD, or will I have to replace it too?
Old May 10, 2012 | 12:05 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
The AOD was used behind 302 engined trucks, my son in law has an 89 that is equipt that way.
Old May 10, 2012 | 12:07 PM
ichabod40's Avatar
ichabod40
I believe all transmissions from this era had the same output pattern, so you should be able to run your t-case.
Az894x4
Feb 15, 2019 10:08 PM
snortf100
May 21, 2009 06:46 PM
OH_VDUB
Sep 24, 2006 08:04 PM
EBronco
Dec 8, 2004 11:16 PM
