Determing which transmission I havr
on
What is the trans code on the drivers door pillar? If it has 5 forward ratios it should be a Mazda M5 which would be the original trans for the truck, but given it's age anything is possible. A ZF5 for a small block engine from an HD truck would swap in, the most obvious difference would be the granny 1st that the M5 doesn't have. There are also a couple older 4 sp gearboxes that could swap in.. some with and some without an OD ratio.
larryejoh
03-26-2013 01:53 AM
Ford204x4
12-28-2002 03:26 AM
